08-17-2022, 09:28 AM | #1 |
Electrical Engineer
Rustproofing for daily driver/winter driver in northern US
I searched the forum, but the rustproofing threads I found were not US based.
In northern IL we have a decent amount of salt on our roads. I'll be using the SS as a daily driver, but will have other vehicles to drive when the snow is deep. I'll have a dedicated winter tire/wheel package. We have our other sedans "fogged" to control corrosion on the interior cavities where they aren't fully painted. Is this car setup with ports for fogging? I've looked into the doors and other areas after having this done and the coating inside was continuous. I know this isn't a popular car to drive in the winter, but I will, so any successful undercoating or rustproofing measures that you have done would be nice to know. If the factory protection is good, then great. If it's anything like their truck beds, then something needs to be done. Around here, a new Chevy truck bed has wheel well rust in about 18 months.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
08-17-2022, 09:37 AM | #2 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Have you asked your dealer or other local business which provides these services?
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
08-17-2022, 10:10 AM | #3 |
Drives: 2015 Camaro Z/28 #311 Join Date: Feb 2018
I drove a 2010 Camaro SS 6 speed car for 8 years as a daily driver. I also used it for my job as I am a traveling repair man. I carried Parts in the trunk for extra traction in the snow. I used blizzack Snow tires. I live near Rockford Illinois and there is plenty of salt up here. When I sold the car with 92,000 miles on it there was not spec of rust on the body. Some surface rust on the under side but zero rot. I never had it rust proofed or protected in any way. GM does a pretty good job protecting the Camaro from the factory. Have you seen any 5th gen Camaros with rust holes yet? I have not. I'm sure the 6th gen Camaro is just as if not better protected from the factory.
08-17-2022, 02:18 PM | #4 | |
Electrical Engineer
08-17-2022, 05:57 PM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Most of our underside is alum or covered. I have driven winters for 6 years and wash the underside at the end of every winter and I have zero rust.
08-17-2022, 10:00 PM | #6 | |
Electrical Engineer
What wheel/tire combo do you run in the winter?
08-17-2022, 11:41 PM | #7 |
2020 Shadow Gray 2SS
Be careful using "rust-proofing" like we did back in the 70's & 80's... Modern cars have coatings even on the unpainted inner surfaces, "rustproofing" will likely plug designed drain holes and such actually making the likelihood of rust much higher... Haven't seen a car with "Ziebart" or "Rusty Jones" in decades... Like since the 80's or early 90's...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
08-18-2022, 07:44 AM | #8 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Don't waste your money. New cars (as others pointed out) come from the factory rust proofed. There is a reason dealerships try to sell you this crap when you purchase a car. HUGE money maker for them. They know they will never have to pay out for it. There is a reason they warranty it for 10 years. Because they know your car will not rust out from the factory in 10 years due to the rust proofing the manufacture already does.
09-17-2022, 07:55 AM | #9 |
Drives: 2017 1LT RS Convertible V6 A8 Join Date: Dec 2014
Check out Fluid Film. Use it sparingly on bottoms of doors and underside lip of hood and trunk lids. These pinch welds are mostly where you'll see rust first.
2017 Camaro 1LT RS V6 A8 Convertible - Silver Ice/Black Cloth, K&N CAI, MRT v. 2 Axle Back, Redline-style Badges and Wheel Hashes, American Authority Grille & a Whole Lot of Attitude
2019 GMC Terrain SLE 1.5T - Blue Steel Metallic/Black Cloth "Soccer Mom Spec" |
09-17-2022, 06:58 PM | #10 |
I am going in to my 6th winter and have zero rust on the bottom of the car.
09-17-2022, 10:02 PM | #11 |
Drives: 2SS 1LE Join Date: Oct 2011
If I drive in those conditions, I try to wash it (underbody) as soon as possible, then having a warm place to dry...
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
09-18-2022, 08:08 AM | #12 |
Electrical Engineer
I've decided the consensus is that frequent undercarriage washes to remove salt is the best approach.
Do the plastic covers on the rear lower control arms collect winter debris? What's the best way to clean them, remove them every spring and clean?
10-23-2023, 08:31 PM | #13 |
Drives: Camaro 1LS Join Date: Jan 2023
I've been Googling around and it looks like I'll have to learn myself the hard way as everyone has different opinions.
In winter months I will wash my undercarriage maybe once a month and report back in 15 years on how it's holding up
1LS 6M Rapid Blue
2000 - 02/04/2023 3100 - 02/13/2023 built & VIN number - 03/01/2023 4300 - 03/03/2023 Delivered - 09/28/2023 |
10-24-2023, 07:07 AM | #14 |
Drives: 2022 Camaro ZL1 Join Date: Dec 2021
I live in the south, but bought this to easily wash the underside of our cars. They sometimes salt our roads.
https://www.theunderwasher.com/
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2016 Hyundai Equus Ultimate 1971 Datsun 240Z |
