08-17-2022, 02:07 PM | #15 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
08-17-2022, 02:17 PM | #16 |
Drives: Chevrolet Chevy Join Date: May 2022
08-17-2022, 03:21 PM | #17 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
My challenger brakes are 6 piston, 15.7" Brembos so I know massive
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
08-17-2022, 04:23 PM | #18 |
Drives: 2022 2SS Join Date: Mar 2022
Options 2 & 3 Chevrolet Performance are LPO Dealer installed meaning your 4 piston fronts are taken off the car. If you do that make sure you get your original 4 piston calipers returned to you. Option 3 the rears are painted red to match the fronts.
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
08-17-2022, 04:53 PM | #19 |
I'm almost sure someone at gm messed up spec'ing this new option. There should be no way they're offering a larger-than-ZL1 brake package for just $995, when the regular upgrade to a smaller, SS 1LE sized kit is north of $3k. I know the copper-free pads that come with it aren't as good, but come on, swap the pads and you suddenly have the absolute best OEM Camaro brake configuration.
08-17-2022, 05:05 PM | #20 | |
Others are too busy knocking on "commie-fornia" to know this is actually a great thing for buyers. |
08-17-2022, 05:27 PM | #21 |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
I have a very similar question and someone earlier in the thread was talking about the copper-free option being a minor upgrade for ss 1le. So, does the $500 dollar copper-free brake system upgrade change the SS 1LE 2-piece rotors and calipers into the larger ZL1 2-piece rotors (about an inch diameter wider) and calipers? And if that’s true will the 1LE logo still be painted on the calipers after upgrading? Thanks y’all.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
08-17-2022, 05:43 PM | #22 | |
I can confirm on my own car, it has the 1LE stamped on the calipers |
08-17-2022, 05:49 PM | #23 | |
Thx
08-17-2022, 05:53 PM | #24 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I was looking to upgrade brakes and it's my understanding there are only 7 RPO codes for Camaro brakes starting in 2021. I understood the copper free upgrade does nothing to increase the size of brake it's an added cost for requiring all the brake lines and pads to be copper free. Your local government adding cost and is required on all cars purchased in CA and Washington. https://static.nhtsa.gov/odi/tsbs/20...86096-9999.pdf
08-17-2022, 05:57 PM | #25 | |
Question : To make a Camaro compliant with the Copper Free legislation, is it just a matter of changing the brake pads? In order to maintain the same braking performance, the brake components have to grow in size and therefore, brake pads compliant with copper free legislation will not fit on Camaro models with traditional copper-containing linings. Keep in mind, the LT1/V6 Body already comes with copper free brakes. The problem is they are puny, especially the rears which are comically puny. Therefore these versions have no copper-free option to tick. You cannot get a BBK on these, just the fronts only, I believe. |
08-17-2022, 06:10 PM | #26 | |
08-17-2022, 06:12 PM | #27 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Yeah this sounds like a win for SS guys. Do it and swap out the pads. I’m a little jealous I paid $3k for my 1LE brakes lol.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
