11-27-2023, 01:04 PM | #1 |
Drives: Camaro SS1LE Join Date: Aug 2023
'23 SS1LE Clutch Pedal Travel
Does anyone have a slight "notch" at the end of the clutch pedal travel? Anytime i depress the clutch pedal, i think i hit the end but then if you apply a bit more pressure, it goes another quarter of an inch further. Have had manual cars all my life so this is definitely not normal.
Mine has had this since day 1 (been waiting 3+ months for a new clutch pedal from the dealer as they replaced the master cylinder but that didn't fix the issue). |
11-27-2023, 09:29 PM | #2 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
I haven't noticed at notch or detent in the travel like you describe. No idea what the cause might be, but sounds like you need an adjustment or replacement part.
