09-16-2014, 06:04 PM | #1 |
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
Smart Phone and Tablet Repair!
Have you have ever cracked your screen or dropped your phone or tablet in water and had to pay hundreds of dollars for a new one? Well no need to worry because I can fix it fast and cheap! You don't need to pay the outrageous prices for the competitors to do it, when you could take it to me for a fraction the price, every time, guaranteed.
I repair iPhones, Droids, Tablets and much more. Cracked screens Water damage Battery replacement Hardware replacement And more!! Quick turnaround time and quality service every time. You can PM me or call/text at (302)598-0942
09-23-2014, 07:38 PM | #2 |
I would like to know more about your water damage repair. How do you fix pitted copper?
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
09-26-2014, 12:55 AM | #3 |
Her Name is Mila
Pitted copper on which part of the phone, internal or external (I assume not external) and what type of phone?
09-26-2014, 12:59 AM | #4 |
Her Name is Mila
But to answer your question, you cant technically fix pitted copper, you can clean it but the only way to "fix" it is to replace it. But please specify on the part your speaking of, pictures would be helpful. And water damage since I am one guy who does this on the side I do not have any fancy smacny machine to do it but I generally take the device apart and apply a couple techniques to hopefully bring the water damaged phone back to life. Its not promised though, if the phone was water damaged and turned back on it has the risk of frying the motherboard (shorting it) which renders your phone nothing more then a parts phone. But some water damage is more extensive then others and some are easy fixes and some cant be done with the technology I have available.
