02-03-2015, 11:13 AM | #29 |
Drives: 2015 Camaro LS 6-speed manual Join Date: Nov 2014
My 2015 LS has the same display for the battery, as well as coolant temp, oil pressure and oil temp in the computer display.
2015 Camaro LS, 6-speed manual
1982 Camaro Z28, built 350, 4-speed, autocross and track day car 2004 Corvette Z06, Millennium yellow 1970 Corvette Convertible, 350 Hp 350, 4-speed |
02-03-2015, 12:58 PM | #30 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Considering, you were using the battery for 45 minutes prior to getting a 12.1v reading, I would say your battery is fine. Batteries should not drop much below 12v or they won't start the vehicle, but to get one to read much over 12.5 with the car off is pretty rare. I've never really found much use for amp draw tests on cars. Batteries and alternators don't cost enough to merit the tools unless you're doing it for a living. Diesels are another story because those parts can be expensive.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
02-03-2015, 02:59 PM | #31 |
Drives: 2014 Camaro 2LS red rock metallic Join Date: Apr 2014
New Alternators
I was informed by an experienced tech that the alternators on the newer GM cars have a regulator that actually turns the alternator on and off. The days of seeing a constant 13.6 to 14.2 volts output are behind us. The alternator now only turns on when a charge is needed. When the battery is charged, the alternator turns itself off. The reasoning behind it all.......increased gas mileage.
02-03-2015, 08:42 PM | #32 |
Drives: 2013 Camaro 2SS/RS Join Date: Jan 2014
Does that battery info show up on every years DIC?
or did I just not cycle all the way through? |
02-03-2015, 08:47 PM | #33 | |
Remember, there are two sets of displays in the DIC. Once has odometer, speed, etc. and the other has oil life, battery voltage, engine health type data. You press the button on the turn signal to switch between the two. It should be there.
02-03-2015, 09:30 PM | #34 |
02-03-2015, 10:06 PM | #35 |
What is the voltage for the mark between the 12 & 19 ? and what is the voltage reading in this pic ?
02-04-2015, 09:44 AM | #36 |
It should be half way between 12 and 19 volts, or 15.5v. That looks to be reading around 14 + or -.
02-04-2015, 10:13 AM | #37 |
On my 2015 LS there are 3 sets of displays on the DIC, the two mentioned above plus the performance displays. The battery voltage shows up in two of them. It appears on a screen, similar to what the OP shows in his pictures, in the vehicle settings. It also shows up in the performance screens as both a digital number and a digital bar gauge on the same screen that shows coolant temperature (also as a digital number and digital bar gauge). It sounds like they added screens and displays to the DIC on the newer cars, even on the base model LSs.
02-04-2015, 10:58 AM | #38 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
On a side note, when I was younger and first started drag racing our "69, I had a switch that I would push that would cut the positive current going into the alternator so that it was basically just along for the ride (spinning, but not producing any charge, so next to no load). When I went through the traps I would pull the switch and it would start charging again. I have no idea what HP we were saving, or how it affected our ET, but its what we did....because we were cool.
02-04-2015, 12:02 PM | #39 |
Drives: 12 Boss 302 Join Date: Sep 2009
Your car is suffering from thermonuclear meltdown, it now junk and a hazardous waste to boot. It will run you about $150,000 to properly dispose of it, but if you send me the keys and the signed title, I'll come by and take it off your hands for free.
Your batteries fine and so is the charging system. If you had been running the radio for awhile, the voltage will be lower.
The biggest mistakes in life come when you know exactly what you are doing.
02-04-2015, 12:52 PM | #40 |
never tried it on the Camaro, but about 11.5 volts is pushing. The compression of the engine and the starter have a good bit to do with it as well.
02-04-2015, 01:30 PM | #41 |
Drives: 2011 Camaro 2SS/RS A6 Victory Red Join Date: Aug 2012
Wrong 1.2 volts per cell = 13.2 volts
2011 Camaro 2SS/RS A6/L99 Victory Red
SLP TVS2300 Supercharger 6psi & Coil Covers. Roto Fab CAI. RX Catch can ZL1 Fuel Pump Kooks 1 7/8" LT Headers w/ High Flow Cats Corsa out the back! NT555R 305/35/20 472 RWHP 466 RWTQ 12.11 @ 114.3 MPH 1.81 60' Pacific Raceways Kent, WA 6/6/13 |
02-04-2015, 01:42 PM | #42 | |
Drives: 2011 Chevy Camaro Join Date: Sep 2010
It's called pulse width modulation or PCM controlled voltage regulator. The "voltage regulator" is part of the PCM. |
