12-05-2022, 04:17 PM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
Possible JMS booster issue
So recently, maybe last month or so, have noticed my lowside pressure isn't meeting commanded. I've been working on the tune with my tuner, and only seems to happen WOT pulls high rpms. Didn't have the issue before, tank pump settings are stock as well. Tuner thinks the JMS may be burning up the pump and shouldnt be maxing more than 16.5 volts. Set it up according to a post on here and haven't had an issue until now. Have had the booster on for about 5k miles. Checked the settings and voltages this passed weekend, maxing out at 17.3 volts, ramps in starting just past 50% throttle and maxes out at about 90% pedal. Anyone here have a similar issue or encounter anything like this? Just trying to get it nailed down before I drop the fuel tank. Thanks
12-05-2022, 06:16 PM | #2 | |
12-05-2022, 06:54 PM | #3 |
Located in socal so not real cold. I've been averaging about 15.5 psi lately with the colder weather so that is definitely a possibility. We're still tuning on 91 so was hoping it would hold up until we got some ethanol in it but maybe that was wishful thinking. On a side not was looking at the dw400 you used from Dixie, how is that holding up? If it is the pump crapping out then would like to use one of those. Gonna run through my logs and see exactly when it started to fall off. Thanks
12-05-2022, 07:20 PM | #4 |
Drives: 21 ZL1 Join Date: Feb 2022
I had the same problem but it was with my MAF. We had been tuning around a bad maf and the car was asking for so much fuel, it was pushing the low side even with the JMS so far past its capability. One new maf and another tuning session later, and mine holds perfect at 76psi+ to redline.
They way you said yours is looking with voltage and how it comes on is perfect operation. You might just have a fuel pump going bad at this point. |
12-05-2022, 08:31 PM | #5 | |
I have not run the DW400 for a long time now. I have the Fore Innovations Triple in tank system. I found the DW400 only marginally better than the LT4 in tank. The Fore triple rocks and wish I would have done it a long time ago.
12-05-2022, 11:17 PM | #6 |
Drives: kia cerato Join Date: Dec 2022
It's most likely the fuel pump, I think. In cold weather, it starts to work worse!!
12-06-2022, 11:39 AM | #7 |
Petro-sexual
I probably get bigger swings in temperature a little further North, but I can go from almost 15-lbs in around 100* temps in the Summer, to 16-plus-lbs now, in the 50s (if I can stay to the wood, lol...). That boost weather is a real thing.
12-06-2022, 02:36 PM | #8 | ||
My tuner said their's only 2 possibilities, bad pump or blockage in the line. Wants to get a mechanic gauge on there to verify. I was just hoping it wasn't the issue but back to the garage i guess. Thanks for everyone's feedback, and appreciate your responses. |
12-06-2022, 08:45 PM | #9 |
Looking back, found a log on 10/30 where pressure held right at 73 or a tad above. Same boost last weekend, similar rpm run down to about 50 psi. Lambda is a hair richer now at .81. Kind of a bummer if it is the pump crapping out, tune was just about dialed in. Oh well, just money haha
12-07-2022, 06:56 AM | #10 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Glad this is getting worked out Aaron... only money indeed
Have you considered cutting an access hole under the back seat vs. dropping the tank?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
12-07-2022, 08:01 AM | #11 |
Yes, still on the fence about it. Would make future access much easier but have a hard time cutting up the car. Probably gonna get a mechanical gauge on it first just to verify the pressure.
