Old 08-04-2022, 02:55 PM   #1
Camrochris
Drives: 2020 Chevrolet Camaro 1LT 3.6L supe
The importsnce of having a OBD2 scanner.
I recently had a code come up that was emissions related. It turns out that running the car with the dual mode exhaust with the quad pipes can cause a code to pop up. It has to do with the inner two pipes on either side get warm, but not hot. I kept running my car in that mode and condensation built up. So I plugged in my new and never used LAUNCH Creader 3001 (2022 version) that I bought a year ago and got the code # and looked it up. All it was is condensation in the exhaust system. Just had to run my cat for 40 mins on thr highway for 45 mins in SPORT mode which obviously will get the whole system hot and dry. I then cleared the code and erased it. I bet that saved an expensive trip to the dealer.
Scotty Kilmer from YouTube recommended it and sure enough it helped me out.
*No batteries required! Runs off the OBD2 port directly.
Camrochris is offline   Reply With Quote
Old 08-05-2022, 06:46 AM   #2
ZPirate
ZPirate's Avatar
A scanner is a nice tool to have. I use a ScanGuage II plugged into the OBD II port as an ancillary gauge on my Camaro and my Z. It will provide you with additional information, much of which is not readily available on the car's gauges. I typically have mine set to display long and short term fuel trims, intake temperature and coolant temperature. However, it is customizable to read many different inputs from the car. It will also read and clear codes.
As for your exhaust issue, I won't likely have that issue as my exhaust is generally in Sport mode. Open the pipes and let them sing.
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 08-05-2022, 07:27 AM   #3
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
I have an OBD 2 unit that plugs in and connects to the Torque App on my phone. I don't use it much, but it does come in handy.
jamala00 is offline   Reply With Quote
Old 08-05-2022, 01:51 PM   #4
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
They're a nice tool to have.
nancygrl is offline   Reply With Quote
Old 08-05-2022, 06:55 PM   #5
JKSully
JKSully's Avatar
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek
An OBD2 scanner is a good tool. Scotty Kilmer is just a tool.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav |
- 1100 - 8/16/21
- 3000 - 9/21/21 - TPW 10/18/21
- 3400 - 10/1/21
- 3800 - 10/20/21 - built 10/19/21
- 5000 - 11/12/21
- 6000 - 11/13/21
JKSully is offline   Reply With Quote
Old 08-06-2022, 05:12 AM   #6
s346k
s346k's Avatar
Drives: like an old lady
weird. the fuse was pulled on mine for 15k miles, never had a cel.
i use hpt as a scanner.
Old 08-06-2022, 06:39 AM   #7
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Yeah I’ve never heard of that one…
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 08-06-2022, 07:28 AM   #8
ZPirate
ZPirate's Avatar
Probably isn't an issue with the V8. I suspect that the LT1 heats up the exhaust pretty good, unless you are driving very short distances. OPs car is a V6.
