11-03-2021, 04:01 PM | #15 |
Depends on mods. At 850ft, my Brothers C7Z was limited to E40 with 2.3 pulley, ported 1.7, cat delete x pipe, vararam, ported 95mm tb, JMS.
Then again I might be running our cars richer then some. I stay around .80-.82 on LT1's and .82-.84 on LT4 stuff. It takes a lot of fuel system to run E60+ at these AFR's.
2016 NFG 1SS A8
11-03-2021, 04:06 PM | #16 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
11-03-2021, 09:03 PM | #17 | |
Drives: HBM ZLE Join Date: Aug 2017
11-03-2021, 09:05 PM | #18 |
No reason to shoot for .80 on an LT4 IMO…
11-03-2021, 09:19 PM | #19 |
Ah ok, I forgot you have the pulley. There’s a measurable trade off with the pulleys and the amount of E you can run. The higher blend plus the cooling (slower spin rate) is why I’m staying with stock pulleys.
11-04-2021, 09:02 AM | #20 |
Dyno Show Queen LOL
I don't think there is a way to put an exact number on it since most power adders are not equal in efficiency and flow.
if ya do go port.. I filed up w e92 last week at the pump then a few days later it was 84 its nice not having to worry about a ratio.
11-04-2021, 10:41 AM | #21 |
There isn't and I am sure it will vary some from build to build...I was just basing the 30whp on what I have seen multiple forced induction cars make with various levels of E. I would say E40 provides 75% of the gains compared to E85, E60 is 90%...etc. E60 is the sweet spot really...Obviously being able to pull up to a pump and just fill up with whatever E is nice, but it's not a big deal if you need to mix it down some. I ran full pump E for a long time and I don't really find it much of a inconvenience to have to mix it down now...especially when my options are mix it down some or shell out a few thousand for more fuel system upgrades to run full E which I might make another 10-15whp. I might still do it just for the smell lol. E40 has a bit more gas smell to it. Once you get to E60+ it smells a lot better out the exhaust.
2016 NFG 1SS A8
11-04-2021, 11:45 AM | #22 |
Right on, maybe I'll have to try another tuner. However, I told him I wanted to be conservative tho, longevity in mind. He says he shoots for .80. I've read Jannetty hits .82. I'm assuming running it leaner than I am now, I can stretch the fuel system further.
As far as blending ethanol, not very hard or time consuming. I just use a percentage based off how much 91 I'm putting in. That or my brewcityboost.com calculator, thing is spot on. |
11-04-2021, 11:49 AM | #23 |
11-04-2021, 12:29 PM | #24 |
My local tuner also uses .82 on LT4
11-04-2021, 06:39 PM | #25 | |
Most tuners will rightfully be conservative on the factory LT1 pistons since they’re cast, so .82 is great. On the LT4 or built LT1, the pistons are forged, so really no need to be ultra conservative. I’m at .84 and runs like a champ.
11-04-2021, 08:14 PM | #26 | |
11-05-2021, 12:05 PM | #27 |
Dynomite dyno, all 3 pulls were within 4 hp
11-05-2021, 01:52 PM | #28 |
I’ve heard those dynos read really low. What mods on the car for those pulls?
