11-02-2021, 09:04 PM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
How much horsepower increase e25 to e70
Ported blower with bolts ons. Wondering how much horsepower I can get going from e25 to full e85 which is around 70% here. Contemplating heads/cam package which would give me a nice bump. However I'm wondering if I go port injection and run full e, it might give me the jump I'm looking for without opening up the engine. Also the port would be a few k cheaper parts/install. Let me know your thoughts, thanks
11-02-2021, 09:08 PM | #2 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Heads and cam ARE opening up the engine tho. Unless you mean pistons and rods which won't be an issue at those levels.
With that setup, 100 octane, and Kong X, you'll be at least 890 horsepower. To the wheels. |
11-02-2021, 09:17 PM | #3 |
Probably 30 whp.
2016 NFG 1SS A8
11-02-2021, 09:28 PM | #4 |
as long as there is an appropriate tune with proper timing and fueling I would agree with 30rwhp
11-02-2021, 09:31 PM | #5 | |
Thanks King, always appreciate your input/knowledge |
11-02-2021, 09:35 PM | #6 |
Right on, might just be holding out and do the heads/cam. 30 horses for the cost of port doesn't seem like the right direction as I won't be trying to push more air, just more ethanol
11-02-2021, 10:24 PM | #7 | |
Drives: 2019 ZL1 Join Date: Mar 2019
HAHAHAHA I just got the joke.. EPIC. lol
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
11-02-2021, 11:35 PM | #8 |
Wanted to ask you a question on your build in regards to the Whipple. Does it not require hood modification or special valve covers like the 2650 does? Could be a selling point for some over the maggie
11-03-2021, 09:04 AM | #9 | |
What fueling mods are you considering to allow you to run that much Ethanol? I am currently talking with my builder about the possibility of upgrading to be able to run full E85. We're going over the costs. It is a lot but I don't believe in skimping out. Gotta pay to play. |
11-03-2021, 09:13 AM | #10 | |
11-03-2021, 09:15 AM | #11 |
If I was doing a LT4 build and had ethanol available first thing I would do is raise the compression...especially when doing a cam that kills dynamic. Ethanol loves the compression and you don't have spin the supercharger as hard to make power.
If I ever do rods/pistons in my LT1, I will be keeping stock compression that way I won't ever need to worry about maxing the Whipple 2.9 out to make power. Should be able to make the same power with 2-3psi less boost compared to stock LT4 compression. Now if we are talking a pump gas build then yea lower compression is a must.
2016 NFG 1SS A8
11-03-2021, 09:38 AM | #12 | ||
At this point, however much power im making, car feels like a rocket 1st-3rd gear. Its only at speeds that would be very illegal on the street which it feels like it could use some more kick |
11-03-2021, 09:49 AM | #13 |
Yea then I would leave compression as is.
2016 NFG 1SS A8
11-03-2021, 11:24 AM | #14 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
