09-25-2021, 10:15 AM | #15 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
09-25-2021, 10:19 AM | #16 |
Regardless if it runs fine, it still needs tuned. The MAF scaling is going to be off because the MAF sensor is now placed in a 5" tube vs 4". Your fuel trims are correcting for part throttle so it still runs but the PE fueling is going to be off.
It doesn't...I have ran them both ways. When I had the regular rotofab that was more of a open box style, the seal made my hood stick up. I ran it without the seal and never noticed any difference in my logs. Either way the only time the car "might" suck in hotter air is when the car is running but not moving. Once driving majority of the air is coming through the grill and entering the airbox.
2016 NFG 1SS A8
09-25-2021, 10:30 AM | #17 | |
09-25-2021, 10:36 AM | #18 | |
Drives: 2019 ZL1 Join Date: Mar 2019
What part of WRONG intake don't you understand lol. The cut is completely wrong and nowhere near the correct shape. Its for an SS not a ZL1. Ive taken my seal off when i had to adjust my hood to mark where i needed to adjust and my IAT1s were 10-15 degrees higher, which are usually 1-2 degrees within ambient readings. So yes there's a difference.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-25-2021, 12:07 PM | #19 | |
I understand its not the correct intake for his car, but that box doesn't fit that much different, its going to be pretty close. There's no need to get so defensive just because someone doesn't agree with you. Ideally, he should get the correct intake for his vehicle, but its not like we're talking about a intake made for Kai Stinger here. |
09-25-2021, 01:24 PM | #20 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
That's the least of the OP's problems, the CA commie CARB is testing for ECM tunes now, unless of course it's not registered and a track toy.
https://www.roadandtrack.com/news/a3...g-smog-checks/ |
09-25-2021, 01:31 PM | #21 | |
ZT Zoomin
Drives: A Slow ZL1 Join Date: Dec 2017
Thank you! Yeah you're not too far at all, I just drove through there on my way to sparks, nv lol. I have a few parts to install and I'm trying to do them all around the same time but things keep arriving damaged. I've had to make 4 different exchanges/returns, I'm waiting on a tb adapter exchange right now.
2019 Crush ZL1
Stock 2017 "FIFTY" 2SS 50th Anniversary Edition ProCharger, Stage II Intercooler, LT2 Intake, Ported TB, Corsa NPP & Double X-Pipe, MRR FS06 20x10/11, Eibach Lowering Springs, MRC, GM Dark Tail Lights & More..RIP https://www.youtube.com/c/ZTZoomin |
09-25-2021, 03:01 PM | #22 | ||
Drives: HBM ZLE Join Date: Aug 2017
09-25-2021, 04:28 PM | #23 | |
