09-23-2021, 08:13 PM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
Rotofab big gulp help
So I recieved the wrong big gulp meant for an ss with lt4 supercharger. They won't ship replacement parts to California. So thinking of shaving the top down because the hoood is sticking up a good 3/16" right over the airbox. Can anyone provide a picture of the top without the seal on it? Just so I have a rough idea of what it's supposed to look like, as I can kind of see where its hitting already.
Thanks for any help guys! |
09-24-2021, 10:15 AM | #2 |
Petro-sexual
I can try to get picks when I get home tonight, but if you go to LMP on Youtube, they've got a bunch of videos where you can see the BG box without the seal.
09-24-2021, 01:34 PM | #3 |
Thank you, I'll check them out. Tried searching but only could find with the seal attached
09-24-2021, 05:15 PM | #4 | |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
09-24-2021, 05:50 PM | #5 |
ZT Zoomin
Drives: A Slow ZL1 Join Date: Dec 2017
Hope this helps.
2019 Crush ZL1
Stock 2017 "FIFTY" 2SS 50th Anniversary Edition ProCharger, Stage II Intercooler, LT2 Intake, Ported TB, Corsa NPP & Double X-Pipe, MRR FS06 20x10/11, Eibach Lowering Springs, MRC, GM Dark Tail Lights & More..RIP https://www.youtube.com/c/ZTZoomin |
09-24-2021, 07:56 PM | #6 | |
You're awesome! This is exactly what I needed, thanks! Just for reference this is the one I got |
09-25-2021, 08:08 AM | #7 | |
Petro-sexual
When are you installing that thing? Cool videos by the way. I'm not too far from you myself.
09-25-2021, 08:24 AM | #8 |
I read the Big Gulp requires a tune to take advantage of all the air.
True or False?
09-25-2021, 08:52 AM | #9 |
True, rotofab states that a tune is needed.
09-25-2021, 08:53 AM | #10 |
Thanks, we'll see i might just try to get the entire setup for the zl1 and sell this one. Probably better bet then hacking up this one because I don't know if it'll seal right
09-25-2021, 09:08 AM | #11 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
To be honest, I doubt the "seal" makes much difference at all, but I would want it to fit well enough under the hood as to not make contact.
09-25-2021, 09:40 AM | #12 | |
Drives: 2019 ZL1 Join Date: Mar 2019
His is not even designed for the zl1 hood so hacking it up correctly is going to take some skill and the proper template.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-25-2021, 09:42 AM | #13 |
It won’t and it needs a tune the MAF will be completely off.
09-25-2021, 10:12 AM | #14 |
It's been tuned the way it is now and has been running fine,its just the hood doesn't sit right. Once I get the correct airbox, I'll send the tuner a log and see if it needs to be changed. I have free tune revisions for life so not a big deal.
