05-12-2018, 12:36 PM | #71 |
Could very well be the case, however it would be nice to have a fully functioning setup.
I just placed an order for 84229269. Last edited by mbnwa; 05-12-2018 at 12:47 PM. |
05-12-2018, 01:47 PM | #72 |
You are correct X2 on P17 is the connection from the HMI X3 (2nd USB) is the connection to the PDR, I am printing a ton of PDF's that I will post shortly maybe it will help some, some will be duplicate postings from prior messages but I think the additional data might be helpful stand by as a gather all the postings.
05-12-2018, 02:29 PM | #73 | |
A11 RADIO X1 (IO5:IO6).pdf B174 FRONTVIEW CAMERA (UQT).pdf F20RA, F39RA, F50RA, F51RA, F52RA, F53RA, F54RA, F55RA AND F56RA.pdf G202 AND G305.pdf HUMAN MACHINE INTERFACE AND DISPLAY, POWER, GROUND, SERIAL DATA AND MICROPHONE.pdf INSTRUMENT PANEL HARNESS ROUTING - REAR LEFT.pdf ISOLATED LOW SPEED GMLAN.pdf JX200 SPLICE PACK.pdf JX201 SPLICE PACK - INSTRUMENT PANEL.pdf K161 VEHICLE PERFORMANCE DATA RECORDER X1 (UQT).pdf K161 VEHICLE PERFORMANCE DATA RECORDER X2 (UQT).pdf K161 VEHICLE PERFORMANCE DATA RECORDER X3 (UQT).pdf K161 VEHICLE PERFORMANCE DATA RECORDER X4 (UQT).pdf K161 VEHICLE PERFORMANCE DATA RECORDER X5 (UQT).pdf K161 VEHICLE PERFORMANCE DATA RECORDER X6 (UQT).pdf LINEAR INTERCONNECT NETWORK (LIN) COMMUNICATION BUSSES.pdf MASTER ELECTRICAL SCHEMATIC ICONS (WIRING SYSTEMS AND POWER MANAGEMENT).pdf NAVIGATION POWER, GROUND, SERIAL DATA AND SIGNALS (IO6 WITH MAW).pdf PERFORMANCE DATA RECORDER (UQT).pdf T4V VEHICLE PERFORMANCE GPS ANTENNA (UQT).pdf X20 MEMORY CARD RECEPTACLE X1 (UQT).pdf X20 MEMORY CARD RECEPTACLE X2 (UQT).pdf X202 INSTRUMENT PANEL HARNESS TO INSTRUMENT PANEL EXTENSION HARNESS (UQT).pdf X203 INSTRUMENT PANEL HARNESS TO INSTRUMENT PANEL EXTENSION HARNESS (UQT).pdf X225 INSTRUMENT PANEL HARNESS TO BODY HARNESS.pdf X53A FUSE BLOCK - REAR BODY BUSSING.pdf X53A FUSE BLOCK - REAR BODY TOP VIEW.pdf I would post it to the forum however ZIP files can only be 3.8MB in size this is around 14MB here is a link to download the PDF pack |
05-12-2018, 04:47 PM | #74 |
So I just got my camera bracket and cover in today while the camera fits in the bracket great and the cover works, the vert has like the 3rd sun shade on the windshield behind the mirror like little dots in the glass, this seems to interfere with the location of the camera and thus might need to adjust the placement or a custom mount to not be in the way of the dots.
@nighttowl does your dash have the mounting point for the antenna or will you have to modify the dash in some fashion to get the antenna to mount? Last edited by mbnwa; 05-12-2018 at 11:41 PM. |
05-12-2018, 04:49 PM | #75 | |
Drives: 2016 Vert 2SS/2018 ZL1 Vert Red Hot Join Date: Dec 2016
05-12-2018, 06:46 PM | #77 | |
Sarcasm loading --------
can you remove some of the dots with a razor blade?
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-12-2018, 06:47 PM | #78 | |
05-12-2018, 06:49 PM | #79 | |
Unfortunately the dots are between the layers of glass / laminate as the windshield is smooth on both sides of the glass. Sent from my iPhone using Tapatalk Pro
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar |
05-12-2018, 07:44 PM | #80 |
That sucks. You either have to swap out the windshield or move the camera somewhere where it clears.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD Last edited by nighttowl; 05-12-2018 at 09:35 PM. |
05-12-2018, 10:55 PM | #81 |
Im making some camera mounting lugs on my 3d printer to test them out. If they test out good ill have some made on monday when Im at work.
Based on the measurements I took the center lug is different than the 2 outer lugs.
05-12-2018, 11:31 PM | #82 |
Cool if they work out let me know I would like to buy 2 sets from you just in case I screw up one set
05-12-2018, 11:40 PM | #83 |
finished making some, they seem like they actually may be strong enough to use out of the plastic.
05-12-2018, 11:44 PM | #84 |
Nice quality, great work they look factory, I wonder if the windshield for the Camaro with the PDR already has the lugs on the glass. However if you decide that you want to sell a set or two let me know I would be happy to buy them.
