#225 | |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#226 |
![]() ![]() ![]() ![]() Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Yeah good call, makes sense
2018 ZL1; Mag 2650, 2" LT Headers and intake, a bunch of SPL suspension upgrades, YYZ springs, sway bars, APEX wheel and SC3R's
#227 |
A few pics from the time attack last weekend -
#228 |
![]() Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
The pic you have of the Z214 next to the Goodyear. Is the Goodyear a 305 vs the 315 of the Z214? If so, that's nuts.
#229 |
Yes, 305/30/19 vs 315/30/18
#230 |
Did you get any ice mode braking problems this time?
Can you comment on how severe and bad it was when you did experience it earlier this year? (was it bad enough that it caused you to almost go off the track and crash? Or was it minor and just caused you to overshoot the corner?) I heard and read that in 2019 they improved and helped fix this issue but that it did not get rid of it completely.
#231 | |
When it has happened, it almost feels as the car accelerates, and typically I run wide, but not fun when you're at pace. Let me look at some data to see what I happening.... Ken
#232 |
Thanks Ken, it sounds like when you have experienced it in the past, it is not as severe as what I experienced considering I am literally going off the track and into the gravel or dirt bank. This gives me hope that the apparent update they did in 2019 has indeed helped fix or at least reduced the severity of the issue when it occurs.
#233 |
![]() Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I just stumbled across your ZL1 video on youtube…… cant wait for the update!!
#234 | ||
#235 |
#16 Ridge Motorsport Park - May 23, 2023
Without Chicane 1:43.22 (PDR) 2019 Camaro ZL1 1LE - first outing I wasn't sure if I was going to start a new thread for this car, but for at least the first few outings, I'll keep the ZLE updates in here as well. I'll add another post about the differences between the SLE and the ZLE...very fascinating and the data is amazing. My goal this week was to do 3 half days to shakedown the car, but ended up only being able to 2 sessions of the first day. (more later as to why) I picked the car up from all the updates/servicing, drove it home to pick my gear and then headed right to the track. Conditions were amazing with 65 degree weather and a light turn out for the evening session. First, let me go through what the car has and what was done to it. 2019 ZL1 1LE M6 - 15K miles - MCS 2 way coilovers - APR Wing - Half cage - Rotofab/Cat back - Tune Updates/Service items - All fluids changed - APR front studs - Giro front rotors/Ferodo 3.12 pads - New OEM rear rotors/ Ferodo 1.11 pads - Airbag light fixed - BMR rear toe and upper control arms - Updated Alignment (-3.5/-2.5) - Lift pads - Intercooler bleed - Weapon X Intercooler - New rear 3Rs - Worn front 3Rs - Baseline MCS clicker setup (FR C-8 R10 / RR C8 R?) Session #1 I decided to run the car with the PTM in Race, as I didn't know the car yet. First impression was the front of the car was very loose under acceleration and the car wandered....a lot. Very much a characteristic of the cold 3Rs..but this was a bit sketch. It got a bit better as the tires warmed up, but I knew I needed to add some rebound in the front. I ended going .01 faster than my best ever SLE lap time, but not thrilled with the front of the car handling wise. Initial impressions were: - Strong motor, but not crazy fast. - Amazing brakes - Extremely good rear grip - Better clutch than the SLE - The transmission shifted easier and the ratios worked much better. - Pretty severe understeer in long radius corners. Session #2 I bled the tires down, added rebound to the front, as well as took out a little compression to get the front to stay down. Immediately, much better and I was rewarded with some solid 43s included a PB of 43.22 (PDR) and 43.29 (AIM) With the TC on, I could basically drive it the same as my SLE and pretty much did just that. I did have to wait on the front to regroup after the front tires went away, I turned the TC off and started to build into a pace and was tracking another low 43 when the car went into limp mode...Limp mode as in, it idled, but would respond to the gas pedal and I had to be towed in. Bummer, but overall pretty happy. When I bought the car, I knew it had a history of this, but it only happened on track and until it failed, I didn't know what it could be. The codes were: P018B and P2635 - both relating to fuel pressure. I cleared the codes and it fired right up. So that was that.... 2 sessions, a PB and now to figure out the limp mode issue. I was also hoping to try it with the square setups, but that will have to wait. For context, here are a few screenshots. 1) ZLE vs SLE 2) Lap times from last week's On Grid Time Attack. We would have been #2 overall on shagged front tires. Very happy and the car is going to be a monster. Next up is in an in depth comparison.
#236 |
ZLE Limp Mode Update -
During my post track day inspection, I found this in the L/R wheel well. Even though the front of the wheel well harness had been moved, with the lowered MCS suspension and the big T7 G-out, it bottomed hard enough to touch the harness on the rear of the wheel well. Here is the relocated harness, now all on the side of the wheel well.
#237 | |
![]() Drives: ‘22 SS1LE M6 Join Date: Nov 2021
I guess I missed where you removed the LT2 intake and went back to stock tune. Couldn’t get those bits dialed in ? Last edited by Open Circuit; 06-11-2023 at 10:13 AM. |
#238 | |
Ken
Thread Tools | |
