#155 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
#12 Ridge Motorsport Park September 30, 2022
Without Chicane 1:45.07 - I wasn't sure if I was going to be bring the car out for this one. The original plan was to drive the day with my son in his GTI and not drive mine, but since the car just came out of a full service and updated alignment, I had to try it. We signed up for an On Grid day, where there were run group and the Time Attack. Going in, I knew the 19" 3Rs were smoked and my front pads were going to be good for maybe 3 sessions. The day started out misty and a slightly damp track and the sun came out about 2pm. Both my sessions I had to use the wipers a couple of times a lap to clear the mist. Changes - Alignment: - At the last day with with Randy, we did a mix of bikes and cars and I coached a rider who is the lead data tech for a pretty major race team. It was great to speak data with him and he had some insight for some new alignment specs, based on my feedback with the car. We went with - Front -3.6 and .08 toe OUT Rear - 2.7 and .04 toe IN Service: Nothing major here except the rear diff fluid was super dirty even though it was only 1500 miles since the last oil change. Results: Right out of the gate, the car was better on entry. The track needed to dry all the way out, but even with the low grip on shagged tires, I did a 46.3, with a passenger. In the 2nd session, I was able to push and easily dropped into the 45s, beating my PB by a tenth. 45.07 vs 45.18 even though I only did a few laps. The car was much much better on straight up and down braking and after turn in to brake release. In fact, I was having to change the way I used the brakes with the additional grip and confidence. Rear grip was also better once the tires built heat. The only negative was I was focused on feeling the new settings and got greedy on direction, not doing a good job of respecting being precise in the longer radius corners, making it push. The nice thing was the car continued to tun somewhat when it did push. Here is a data graph with the previous alignment and the new alignment. (Red previous PB - Blue new alignment) There are some differences for sure on driver input, but the differences can been seen more on the brake pressure side, achieving a faster entry due to having to use less brake pressure. The fact this was done on smoked tires, is very encouraging. Unfortunately, I felt a vibration halfway through the 2nd session and pulled in. The L/F tire had corded pretty good and I had to call the day. Bummed, but a great problem to have... I'm not sure when I'll drive it next, but hopefully I can get out for a day with some freshie's before the end of the year.
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#156 |
![]() Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
Ken is that the L/F inside corded or outside? Thx
#157 |
It was on the the L/F inside....BUT, I have never had an issue with the fronts cording, only the inside rears on 3Rs. The corded tire was previously on the L/R before this day and I knew it would be thin...
Ken
#158 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I'm surprised that going to the stiffer Hotchkis/BMR bars over OE SS 1LE bars yielded better 3R grip. Between the stiff DSSV springs rates combined with your previously used setup of the OE SS 1LE bars (which are stiffer than the ZLE bars) just adds to that surprise. Bar stiffness: Hotchkis/BMR>SS 1LE>ZLE Do you think that maybe the increase in grip is a result of better camber control of a flatter platform? Or just the F/R delta of the Hotchkis/BMR settings brought the balance in mid corner? Also on the front bar preload, did you shorten both front endlinks or just one? Thank You
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD
#159 | |
#160 |
Very interesting on the bars, Ken, thank you.
Looking at your latest alignment specs, I see you spec'd .04* toe in at the rear, which is about .018". That is less toe in than the GM specs (.10*). What was the thought on going with less toe in vs what you had prior? I would think going less toe in would be detrimental to getting the power down on exit, but I wonder with the eLSD programming that might not be the case.
#161 | |
It certainly is much much better on straight up and down braking, as well as turn in. Exit grip was also better, no clue why. Unfortunately I did test this on very worn tires and not doubt it will be better with freshies. Ken
#162 |
What are your Hotchkis/BMR bars set at? Full soft?
Since the typical aftermarket bar is attached to the chassis with a poly mounting bushing that does not grip the bar as tight as the OE super tight mounting bushing I wonder if the bar dynamics are playing a part in the results of the Hotchkis/BMR setup. Happy Thanksgiving!
#163 | |
Ken
#164 |
Not really an update, but a fun comparison I was able to do -
https://www.camaro6.com/forums/showthread.php?t=614504
#165 | |
![]() ![]() Drives: 2022 VOM 2SS 1LE M6 Camaro Join Date: Nov 2021
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500 20211208 - 3000 (TPW: was 20220103, now 20220124) 20211220 - 3400 (TPW: 20220110) 20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle) 20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223) 20220212 - 4800 --- 20220216 - 6000! 2024 Silverado EV RST First Edition on reserve, as well. |
#166 |
It's pretty staggering what our cars are capable of. On another note, I have 3 days scheduled with my car in the next 2 weeks. Looking forward to some proper updates! Ken
#167 |
![]() Drives: 2017 Prius, 2018 Armada Join Date: Jul 2022
What days are you going to be at the track? I live about 10 minutes away from the Ridge, and would enjoy watching you lap your Camaro on the track. I have a Zl1 on order that I am hoping to bring to the track this summer and I will be looking for other Camaro owners to meet up with.
Eric |
#168 | |
Ken
Thread Tools | |
