06-09-2010, 03:28 PM | #15 | |
Petro-sexual
06-09-2010, 03:38 PM | #16 |
Drives: 2010 Camaro Join Date: Feb 2010
Yes, you can fit a 17" SJM/Bogart wheel right over the brakes. They fit like a tight glove. Here is a pic of them on my car.
06-09-2010, 04:38 PM | #17 | ||
Petro-sexual
+1 to the post though |
06-09-2010, 04:46 PM | #18 |
would my Weld Wheels with my 27 x 11.5's Hoosiers that I have on my 88 Camaro fit on my 2010?
06-09-2010, 04:54 PM | #19 | |
This why I never feel embarrassed about asking a single question on this forum.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
06-09-2010, 05:14 PM | #20 |
Petro-sexual
06-09-2010, 05:23 PM | #21 |
Chief,
I had the wheels made by SJM/Bogart. The wheels were $1419 and about $50 to ship. The tires I got directly from Hoosier at $199 each. And then I need speacial lug nuts ( the stockers don't work) so that was $50. The entire package was roughly $1900. I have no clue about the other wheels. I would think that they wouldn't. Worse thing is that you try and find out for sure. |
06-09-2010, 05:25 PM | #22 | |
Petro-sexual
06-09-2010, 05:33 PM | #23 |
Radz,
I can feel your pain. I dumped my 18" drag radial set-up for the SJM's and actually cut a worse 60'. The best I could do on the slicks with the stock stall was a 1.65. With the stock stall I can't leave any harder than 1450. Otherwise, with the front wheels lockes, the car pushes itself down the track. Thats why I hopeful that the Pro Torque being built for my mods and my car specifically will really kick the baby in the ass. Ted did all the ordering so I'm pretty sure it'll be dead on!! |
06-09-2010, 05:53 PM | #24 |
Drives: 2010 Summit White 2SS SIM Stripes Join Date: Sep 2009
SuperchargedSS, thats one of the most impressive cars on this site. A stock L99 motor running 10s is awesome! Hope the stall helps. Any plans on changing rear end gears?
06-09-2010, 05:58 PM | #25 | |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Ah, next time just rev it to 4500 in neutral and drop it in drive - just like a high stall converter... j/k Can't wait to see your 60' with that new converter. |
06-09-2010, 06:08 PM | #26 |
Maybe gears next. I always forget to check my rpms as I go through the traps so I can tell Ted. I don't want it shifting into 5th. I'm trying to stuff in stages now. First was the slicks. Now the stall. Then the fuel system and more boost, and then gears. When our weather gets good again, the car should do 10.50's without ever opening anything on the engine. Thanks for the kind words guys!!
06-09-2010, 06:17 PM | #27 | |
SST...
Because your car in first is the same as a 4L80/4L85E with a 5.31 rear gear. 6L80E 4.03*3.27 in 1st = 13.17 which is the same as a 4L8xE with a 5.31 rearend ratio. |
06-09-2010, 06:30 PM | #28 |
I'M surprised your car can be thinkin about shifting into 5th as most of guys that run the 1/4 are just good into 4th on autos. Please give us more info on your 6l80e tune. thanks
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Hello First Post, looking at getting one next year | Rocketright | 5th Gen Camaro SS LS LT General Discussions | 11 | 12-11-2009 07:02 AM |
I WILL CHOOSE MY THREADS MORE CAREFULLY, TO POST IN. | SQUALO | Canada | 101 | 11-22-2009 08:20 PM |
Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) | TAG UR IT | USA - Texas | 41 | 10-19-2009 08:56 PM |
Craigslist + Post = unhappy Dealers | TiE2000 | 5th Gen Camaro SS LS LT General Discussions | 75 | 09-27-2009 05:15 PM |
