05-19-2020, 03:06 PM | #1 |
Drives: 2017 ZL1 with Lingenfelter 720hp Join Date: Dec 2018
Next Mod?
I looking for ideas for my next mod. I currently have the Lingenfelter 720hp(which includes the 9.1 pulley)package along with 2” kooks headers and a rotofab cold air intake. I have no cats on my car with stock mid pipes and stock exhaust. I had a custom Dyno tune done along with the TCM tuned as well. My car made 642RWHP/735RWTQ on the Dynocom Dyno. I am wanting to get another 50-100RWHP. I am not looking to tear the motor apart to achieve this. Trying to find the best bang for the buck with my set up that is safe. Here are my thoughts. Please add your input or any other ideas.
-E85? What’s involved to go this route? how much more power? -Ported TB? How much more Power -Ported Stock Blower? How much more power -Meth? What’s involved in this? How much more power? Safe? -Cam? What’s involved in this? More Fuel? How much more power? -Full cat back? How much more power See attached current Dyno sheet Last edited by NICKEL1810; 05-19-2020 at 06:27 PM. |
05-19-2020, 03:20 PM | #2 |
Drives: 2018 ZL1 Join Date: Oct 2019
I assume you have done a pulley?
E85. Get a flex fuel kit, which is easy to install. It will let you run E30-E50. Only downside is you need to mix gas
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
05-19-2020, 06:29 PM | #3 |
Yes I have the 9.1 lower pulley. Would I have to get it retuned if I go this route? Also what kind of gains would I get? What is the best way to mix the gas to ensure you are getting the right amount? Thanks
05-19-2020, 06:44 PM | #4 |
Problem with E is it eats away at what you have for fuel volume. You could probably run E30 or so at your HP level, which is still worth it IMO. Add that, at least a 95mm TB, and a ported blower for some easy HP. Probably 50-60 HP between those.
05-19-2020, 06:48 PM | #5 |
AXLERODZL1
Drives: 2019 Riverside blue ZL1 Camaro Join Date: Dec 2018
i got the same kit you have... with a little more.
look at my sig.
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout Roto-Fab Big gulp 103 TB Lingenfelter Lower Pulley(9.17) 1 7/8 ARH headers and Exhaust Meth injection(single nozzle) 733whp/788tq |
05-19-2020, 07:22 PM | #6 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
Go for meth. You got the pulley which you have to pull timing. A 50/50 mix meth kit will let you get some of that timing back in a tune and boost the octane. Cooling your IAT. That would probably cost almost 2k with the install and tune
05-19-2020, 09:03 PM | #7 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Ported blower and 103TB or at least a ported 95mm will make about 40RWHP.
Meth will add on the light side about 30RWHP. Cam about 50RWHP. Catback about 0-2RWHP. Not worth it to me at all. (If you have headers all ready and then add catback, it’s going to be loud. For reference, I have full boltons: cam, meth, headers, BIG gulp, 103TB, ported stock SC, and made 780whp on a mustang dyno. Personally, I probably could have made 720whp and would have been happy. I just didn’t know all these parts would make that much power. Car is crazy fast. |
05-19-2020, 09:06 PM | #8 |
199
Drives: like a granny Join Date: Apr 2013
I'd stay away from meth. modules go bad, pumps go bad, nozzles clog and if it leaks, you have a serious fire.
if you did go with meth, don't use the washer tank as your meth tank. I'd vote for e85, good safe power and it will run cooler.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
05-19-2020, 09:37 PM | #9 |
Drives: 2018 ZL1 Join Date: Mar 2019
I would add Tony Mamo's Version 2 Ported Throttle Body. Best mod for the $$. You will make a nice dent in your power gain goal for under $400 and make your car more drive-able.
***2018 ZL1, CALLAWAY SC750, NFG, 6 Speed, Carbon Fiber Hood Insert, PDR, Carbon Fiber Dash, Tony Mamo V2 TB, Borla S-Type Cat Back Exhaust (Carbon Tips), Hurst Short Shifter, Eibach Performance Springs, IROC Blade Spoiler, GM Dark Lens Kit/Reflectors, Diode Dynamics Smoked LED Side Markers, Wildhammer Carbon Steering Wheel, CF Shift Knob, Titanium Lug Nuts***
05-20-2020, 07:59 AM | #10 | |
05-20-2020, 08:10 AM | #11 |
I believe you shouldn’t have fuel issues until you are at about 700whp. With what you currently have plus adding the ported SC and 103TB I think you’ll be fine and right about 680-690 whp. You can get a low side pump booster to help with fuel as well. These are a little under $500. I’ll be doing that soon. It’s not needed at this time but I want the fuel trim to never be low so it’s added insurance.
05-20-2020, 08:17 AM | #12 | |
05-20-2020, 08:59 AM | #13 |
So you're set up is pretty close to our stage 1 package. When guys are ready to step up our stage 2 package adds a ported Jokerz blower (or Kong if you want) and a 103 Nick Williams TB. Usually adds another 50-60rwhp and really makes for a nice max effort bolt on car. We done a few with meth and some interchillers. These cars really do like meth.
E85/flex fuel is great but at your power level you really can't run much more then E30 without fuel system upgrades. You might be able to gain 25-30rwhp but it can be a headache because if you add to much E you can cause damage. We had a customer consistently tell us how bad his car was running because he kept putting to much E in it and it leaned out. If you want to run more E a cam and a low side upgrade are recommended. |
05-21-2020, 08:20 AM | #14 | |
Jannetty Racing Super Street Brawler package. Magnuson TVS 2650 JRE Road race blower cam package in either smooth or rough Idle. JRE 95mm Throttle body conversion. JRE custom tune via HPtuners. Expected RWHP on 93 octane 830-840 RWHP 203-753-7223
www.jannettyracing.com
