Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 02-09-2020, 11:50 AM   #1
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
Need wheel and tire help
Help me out if you can. Need some experience from those who have changed wheels and tires before on 5th gens.
I am thinking about getting new wheels and tires as I will soon need new tires anyways. Here are the two setups I am thinking about going with. Please let me know how this will effect possible ride characteristics and fender well gap. I am not concerned about getting the car re calibrated with a tune as it is already tuned. Stock Diameter is 28.7
My 1st choice for wheels and tires
TSW Nurburgring 19X9 (offset?) with 255/40ZR19 Michelin pilot sport AS 3+(overall diameter will be 27.1)
TSW Nurburgring 19x10 (offset?) with 285/35ZR19/XL Michelin pilot sport AS 3+ (overall diameter will be 26.9) (effective gear ratio change 3.49
My 2nd choice for wheels and tires
TSW Nurburgring 20X9 (offset?) with 255/40ZR20/XL Michelin pilot sport AS 3+ (overall diameter 28)
TSW Nurburgring 20X10 (offset?) with 285/35ZR20 Michelin pilot sport AS 3+ (overall diameter 27.9) effective gear ratio change 3.36
Like I said I am more concerned with ride characteristics and fender gap but these wheels look really good on the 5th gen and are much lighter even in a 20 inch wheel then the factory weights on them. So I am looking for a slight performance increase and I wouldn't mind a smaller diameter wheel and tire to give a little change in rpms or the feeling of maybe giving it a slight gear change.
Please give me any input you all know. I am defiantly not sure about offset or if these will require spacers. Thanks
ss camaro-monte is offline   Reply With Quote
Old 02-09-2020, 03:24 PM   #2
charles71
charles71's Avatar
Drives: 2011 Camaro SS
with both of those sizes the front wheel & tire will be a little taller than the rears. The average person may not notice it but if you are like me (OCD) you will and it will annoy you. A 275/40/20 and a 315/35/20 will be the exact same size and perfect for our cars. I run a 20x9.5 and 20x10.5 with those tires with no issues and I am lowered 1.5 all around
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 02-10-2020, 09:17 AM   #3
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
This...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 02-10-2020, 10:14 AM   #4
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
You could also do 19x10 or 20x10 with 275/40 or 285/35 on all four corners with +23 or +35 offset. IMO, If you’re only going 285 width in the rear, I’d square up the tires and get rid of the inherent understeer.
SSammy is offline   Reply With Quote
Old 02-10-2020, 10:36 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ Exactly, is what I am running...20x10 front, 20x11 rear..
1JEWLDSSRS is offline   Reply With Quote
