12-17-2019, 02:01 PM | #1 |
Drives: 2011 Summit White Camaro SS Join Date: Feb 2018
Looking for 1LE front chin
Hey I have a 2011 SS and Im looking for the black chin that goes on the bottom of the front spoiler (the one from the 1LE) or something really close to it. Can someone point me in the right direction?
12-17-2019, 02:05 PM | #2 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
It's called a splitter
12-17-2019, 02:16 PM | #3 |
12-17-2019, 02:20 PM | #4 |
You might want to post in the classified ads section or in the exterior modifications section or the or the 1LE section or the general section. Any of these will probably get you more of a response than any of the engine, drivetrain, powertrain sections.
12-17-2019, 02:48 PM | #5 |
12-18-2019, 12:11 AM | #6 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I think the point he was trying to convey to you is that when you know the proper name it makes it possible to actually search for it online.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
12-18-2019, 05:08 AM | #7 |
Good luck finding a 1LE splitter for the 13 or lower front end, if you do they are quit spendy. Aero Sport Concepts has a splitter for our 2010-13 front ends.
Orange Krush II
12-18-2019, 09:15 AM | #8 |
Tri-County Camaro SWFL
SLP makes a similar (not sure if you can get it anymore)
ACS composite makes a similar OEM, check out GM direct or search for a SS Dusk Edition splitter or Hot Wheels edition splitter.
12-18-2019, 01:12 PM | #9 |
I'm looking an yea these things are either really expensive or look a little cheesy. Thank you to everybody that helped out.
