Old 12-22-2018, 10:44 AM   #1
Marotrent
Drives: 2011 Summit White Camaro SS
Crank up problem
Turning on my car this morning it took a while to turn over and when it finally started all of my stabillitrack was turned off. Also it felt like I wasn’t running with all cylinders. Has this happened to anyone else?
Marotrent is offline   Reply With Quote
Old 12-22-2018, 10:51 AM   #2
RankSS
Drives: 2010 Camaro SS
Fully charge the battery. Might be a good idea to have battery tested.
This is a common problem when battery voltage is not optimal.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 12-22-2018, 10:55 AM   #3
Marotrent
Ok thanks. I’ll do that today
Old 12-22-2018, 06:21 PM   #4
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
My battery lasted 2 years - in a brand new 2015. Between the gear drive starter, high compression and electronics, they may have not made enough battery for these cars. Change ‘er out...
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 12-22-2018, 09:24 PM   #5
Spec
Drives: 2010 Camaro 1SS LS3
This happened to me a couple of times when my starter was going out about 20k miles ago. Hasn't done it since I swapped it out.
Spec is offline   Reply With Quote
Old 12-22-2018, 10:53 PM   #6
SharpOldNo7
SharpOldNo7's Avatar
Drives: 2015 2LT RS Convertible
Take the cables off and clean the post and cable clamps. Lead post will build up a scale like coating between the clamp and post. Clean all ground connections you can get to as well. While the battery is out, have it tested under load after you have put a 3A or smaller charge on it until it is brought up to 100% (if it will charge up to 100%). Replace the battery if needed but if you replace it, slow trickle charge the new one until it is freshened up from sitting on the shelf.
SharpOldNo7 is offline   Reply With Quote
