05-16-2018, 08:15 PM | #1 |
Drives: 2016 Camaro SS Join Date: Jul 2016
Cam Shake
Hello,
My car got installed TSP stage 1 CAM, and feel a lot of shake at idle sometimes. I was told the cam doesn't have that rough idle, but not sure if it is. If you see the video and see the coolant bottle, you can see the shake easily. Can I reduce the shake by tune? or just it is natural with CAM? https://youtu.be/g7_yMJXwVYg Thanks, |
05-16-2018, 08:34 PM | #2 |
Drives: 16 Camaro 2SS Join Date: Feb 2017
What is the LSA?
05-16-2018, 08:37 PM | #3 |
BAMF SS
Could be loose motor mounts.
05-16-2018, 08:58 PM | #4 |
05-16-2018, 09:01 PM | #5 |
05-16-2018, 09:38 PM | #6 |
05-17-2018, 06:13 AM | #7 |
BAMF SS
05-17-2018, 08:14 AM | #8 |
Drives: MB 1SS Join Date: May 2017
The LSA doesn't dictate the shake. If there is some chop at idle the motor will wiggle. I've had all sorts of cams and they all had some shake/vibration at idle.
05-17-2018, 08:31 AM | #9 |
LSA does not have anything to do with cam lope...Overlap does.
That being said, from what I see in the vid looks normal. The engine shakes as it comes in and out of loping...typical for a cam car. You could probably smooth it out some more with tuning.
2016 NFG 1SS A8
05-17-2018, 09:24 AM | #10 | |
BAMF SS
OOORRRR by using duration and subtracting LSA (add durations, divide by 4, subtract LSA, then multiply by 2) So the tighter your LSA, the less you would subtract from your durations, which means you would have a higher number (which means more overlap) also, here are the cam specs for the OP's cam, from TSP's website Cam Specs:*227/231, .635"/.635", 116 LSA it's a pretty small cam, with a pretty wide LSA, which would make sense for a blower car. Again, I would look at the fueling at idle. Running a car rich at idle is an easy way to get it to start, but leads to crappy idling characteristics. I remember when I was messing out with a 231/236 cam in my 5th gen, and I threw so much fuel at it, at idle, it would sound like a TREX camm'ed car. bbuuutttt it would foul the plugs in 2 blocks. lol. |
05-17-2018, 10:07 AM | #11 | |
How can I adjust the fueling in close loop for gen5 lt1 engine? I believe that the fuel trim always tries to make AFR to the stoich while the overlap of cam leads o2 sensor to lean condition, and it will make the cylinder the richer. |
05-17-2018, 12:55 PM | #12 |
This is not a fuel or timing issue I have seen the logs.
Pretty normal for that cam. Ted.
www.jannettyracing.com
05-17-2018, 01:03 PM | #13 | |
Drives: 2016 2SS Join Date: Jul 2016
If Ted says the logs are good then they are good. That cam isn't all that small but I think the overlap at .050" is very minimal.
05-17-2018, 02:30 PM | #14 | |
also since it's a vvt cam, depending how far advanced it is at idle could contributing to the cam chop. I believe that is why most VVT NA cams use a higher LSA.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 05-17-2018 at 02:50 PM. |
