03-19-2018, 10:39 PM | #15 |
Drives: 2014 Camaro SS Black Widow Join Date: Mar 2018
Im over $20,000 into my cars mods and regret it
03-19-2018, 10:55 PM | #16 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-19-2018, 11:14 PM | #17 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
You have to Pay to Play and in the dictionary “PAY” comes first. I should have invested in a dictionary!
I would start with a plan having an end game in mind. The biggest problem is most don’t stick to their plans.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-20-2018, 12:35 AM | #18 |
Drives: 13' 1LE Join Date: Apr 2012
Headers/tune/CAI. Or HFC/tune/CAI
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-20-2018, 01:39 AM | #19 |
Drives: BlownSS Join Date: Mar 2018
I have a set of ID 850 fuel injectors A tour converter and a cold air kit for you
03-20-2018, 09:21 AM | #20 |
Drives: 2011 Summit White Camaro SS Join Date: Feb 2018
Thanks guys you all are very helpful, it seems like I will start with the CAU and tune. Probably save up a little then go for the headers.
03-20-2018, 09:25 AM | #21 |
03-20-2018, 09:26 AM | #22 |
03-20-2018, 09:28 AM | #23 |
03-20-2018, 09:52 AM | #24 |
Do a search, but CAI ended up with the better numbers on a test IIRC
2011 L99
CAI, SE LTs, 3.91 gears 2013 L99 3.91 gears, OBX LT, CAI, NO 100 shot, BMR Toe Rods, trailing arms. SOLD |
03-20-2018, 10:01 AM | #25 |
Drives: Camaro and Sierra Join Date: Jul 2012
You're in Florida. I'd go to redline or tampa tuning for a tune. Whichever is closer but they are both good.
03-20-2018, 10:38 AM | #26 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
get a vararam otr cai since you have a 2011, some TSP 1 7/8" or 2" long tubes and a tune
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-20-2018, 10:42 AM | #27 |
Instagram: Sangstah
CAI (rotofab, cold air inductions), then headers (speed engineering on a budget) and then I would recommend a Dynosteve SCT tune. That should put you around a grand
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-20-2018, 01:56 PM | #28 |
Drives: Black 2011 2SS Join Date: Oct 2017
I just purchased a CAI intake and a SCT handheld time with lifetime tunes from dynosteve for around $750-$800. The CAI was tested to jannetty racing with the best HP gains.
