12-30-2013, 10:07 PM | #15 |
Drives: 2012 ZL1 M6 Summit White Join Date: Dec 2013
Looks about perfect to me...could be lowered an inch or so...adjustable Pfadt's front and rear-coil overs are on my ZL1...full adjustable up or down. Rides perfect.
12-31-2013, 01:52 AM | #16 |
Drives: Camaro ZL1 Jg. 2012, M6, black Join Date: Oct 2011
your suspension are adjustable? you no longer have the oem magnet ride suspension?
12-31-2013, 10:12 PM | #17 |
With the Pfadt adjustable coil-overs, you are just moving the springs up or down...a machined ring threaded around the shock tube (Pfadt part) can be turned up or down to raise or lower the ride height...MRC shock tube, wire, is intact, works as it should...MRC jut dampens the shock rebound every inch the car rolls. The springs lower it down...or in this case you can raise the body up also.
WWW.pfadtraceengineering.com |
Tags |
goodyear, michelin, performance, tires, track |
