Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 03-20-2019, 09:22 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: Camaro Hood Spears Kit
2019 Camaro Hood Spears Kit
Giving your Camaro a fresh new look is easy with this 2019 Camaro Hood Spears Kit. This Stinger Stripe is manufactured from the highest quality materials available using vinyl from leading manufacturers like 3M, Hexis, KPMF, and Avery. We select the vinyl-based on color samples and what is most accurate for your Camaro.
All of our Camaro stripe kits use an air release backing. This allows for an accurate installation. All of the vinyl we use is also UV protectant and comes with a pressure sensitive adhesive for a quick installation and a long life.
In addition to this Camaro Hood Spears Stripe Kit, we also sell hundreds of other stripes and designs ranging from hood stripes, side body stripes, racing stripes, fender hash stripes, door and rocker stripes, hood vent inserts, side scoop inserts and more.
All of our Camaro stripe kits are custom made and ship within 1 business day. Since our stripe kits are custom made they are non-returnable.
Inspired by the factory style graphics, this stripe covers the recessed area between the two raised body lines on the hood of 2019 Camaros. Available with or without the cutout for the SS hood vent. LS and LT Camaros would select no hood vent cut out. SS Camaros could use either style, no cut out will require removing the vent for stripe install. Includes hood stripe only.
Will fit all 2019 Camaros except ZL1.
Check it out here: 2019 Camaro Hood Spears Kit
southerncarparts is offline   Reply With Quote
Old 04-13-2023, 02:15 AM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...pears-kit.html
