Old 03-11-2019, 01:39 AM   #1
NerdChop
NerdChop's Avatar
Drives: 2018 Chevrolet Camaro LS
2018 4 banger doesnt have a performance timer?
I see u guys posting pics of the 0-60 timer. My camaro doesnt have that. Instead it is just a plain stop watch timer....useless.
Am i missing something or is that just how the 18s are?
NerdChop is offline   Reply With Quote
Old 03-11-2019, 05:32 AM   #2
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Page 128 of the owners manual says some items in the Driver Information Center may be off by default and can be turned on through the Settings or Option app.
17rsvert is offline   Reply With Quote
Old 03-11-2019, 08:16 AM   #3
zts1986
Drives: 2019 Chevrolet Camaro 1LT 2.0T
You need the RS or 1LE package on the 2.0T if you want that option, I believe.
I bought the OBDLink MX+ and it has a 0-60 timer on it, using data from the ECU. It's a pretty impressive tool for $70. More engine info than I could have imagined right from the stock app.
zts1986 is offline   Reply With Quote
Old 03-11-2019, 10:21 AM   #4
irobles3680
Drives: 2017 2.0 Camaro LT
Even cheaper option to buy bafx obd2 for $20 and then use torque pro app for $5 0-60 times measured and a lot more like hp and torque
irobles3680 is offline   Reply With Quote
Old 03-11-2019, 11:31 AM   #5
zts1986
Yeah, OBDLink app is free to download. I'm currently using it to track: fuel rail pressure, throttle position, fuel rate, O2 sensor, boost, air/fuel ratio, intake pressure, mass air flow rate, engine power, engine torque, 0-60, and 1/4 mile times.
I checked out the BAFX module but I didn't like how long it was. I like the shorter profile of the OBDLink. It's really tucked up in there.
Old 03-11-2019, 11:40 AM   #6
NerdChop
NerdChop's Avatar
That sounds cool.
Have any 18 owners esperienced what im talking about and fixed it?
I vaguely remember reading that the performance timer was done away with because too many problems came about from people going 0-60 WoT all the time
Old 03-11-2019, 11:50 AM   #7
irobles3680
I have a 17 doesn’t have timer either you probably have the lt or ls model
Old 03-11-2019, 12:55 PM   #8
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
You guys need to spend some time with the owners manual. They ALL have a performance timer. My car is an base 18 LT, it has it.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-11-2019, 01:04 PM   #9
ToeKnee Sea
Drives: 2018 Camaro SS 1LE
Camaro comes in a 4 banger?
ToeKnee Sea is offline   Reply With Quote
Old 03-11-2019, 01:08 PM   #10
zts1986
On the 2019, the performance variables (friction bubble, performance timer, etc...) is available with the "uplevel cluster" instrument cluster. My 1LT does not have that. I have the base instrument cluster and the options within the cluster menu are limited.
Old 03-11-2019, 01:54 PM   #11
cooper1965
Coopers Camaro
cooper1965's Avatar
Go have a seat rook.
OP, has a 17, Irobles has an 18, Nerdchop has an 18, I was talking to them, as your info about needing rs or 1le is wrong. You didn't mention having a problem on your 19.
Old 03-11-2019, 04:19 PM   #12
DarkFangz1100
Drives: 2016 Camaro SS
Have a 2016 1LT....just go into your settings and turn it on
DarkFangz1100 is offline   Reply With Quote
Old 03-12-2019, 08:07 AM   #13
zts1986
My bad...but why on earth would these features be removed on the 2019?
Old 03-12-2019, 08:57 AM   #14
Austin_504
Drives: 2016 Camaro RS 2.0t
I met a 2019 2lt that showed me his best time in his cluster.
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
Austin_504 is offline   Reply With Quote
