11-16-2016, 08:17 AM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
6th Generation Camaro aFe POWER MACH Force-Xp 3" 304 Stainless Steel Cat-Back
2016-2017 6th Generation Camaro aFe POWER MACH Force-Xp 3" 304 Stainless Steel Cat-Back Exhaust System 49-34069-B $1936.12
Advanced FLOW engineering (aFe) was founded in 1999 and is headquartered in Corona, California, USA. They are a manufacturer of automotive cold air intake systems, performance air filters, fluid filters, intake manifolds turbochargers, programmers, throttle body spacers and exhaust systems. aFe facilities feature in-house CNC machining, CAD design, 3D printing, 3D scanning, fabrication, dyno testing, mandrel tube bending, flow and filtration testing. This cat-back exhaust system incorporates factory style NPP dual mode exhaust valves which use the factory exhaust valve motors (not included). The valves help regulate, direct and control the flow of exhaust gasses by opening, closing, or partially obstructing passageways depending on throttle position for maximum performance.In testing, the cat-back exhaust system produced a max gain of +13 horsepower and +10 ft. lbs. of torque verified by our in house dyno Dual free-flowing mufflers are used to absorb high pitch tones producing a powerful sound and unleashing all available horsepower and torque.The performance cat-back exhaust system is constructed of 3" mandrel-bent, 304 stainless steel tubing for maximum performance, corrosion resistance and strength eliminating cracking.The equalizer balance tube evenly distributes exhaust pulses traveling through the exhaust system. This creates a more efficient flow for better performance while minimizing exhaust drone.This MACH Force-Xp cat-back exhaust system uses factory mounting locations providing stability and a hassle-free installation. Finishing off this system are quad gloss black, 4” diameter tips. The tips come with a laser-etched aFe power logo for an aggressive style.High-quality band clamps are used for a complete 360 degree sealing surface. Note:This system does not fit convertible models All aFe exhaust systems are engineered and manufactured in our Corona, California manufacturing facility. https://www.rpidesigns.com/shop/item...p--49-34069-b/ See This And Many More 6th Generation Camaro parts On Our Website RPIDesigns.com Last edited by RPI Designs; 04-13-2017 at 09:00 AM. |
01-24-2017, 10:50 AM | #2 |
Drives: 2016 1ss Camaro Join Date: May 2016
i have this kit on my vehicle and love it and they have sound clips on the afe website!
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
09-25-2019, 02:10 PM | #3 |
2016-2018 6th Generation Camaro aFe POWER MACH Force-Xp 3" 304 Stainless Steel Cat-Back Exhaust System 49-34069-B $1936.12
https://www.rpidesigns.com/shop/item...p--49-34069-b/ See This And Many More 6th Generation Camaro parts On Our Website RPIDesigns.com |
