09-26-2017, 07:24 AM | #15 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Good eye on that one....
2017 Grand Sport, Borla X Pipe.....Enough Said
09-26-2017, 08:44 AM | #16 | |
Dyno Show Queen LOL
Hell no I would't been able to make my Car payment if I bought this stuff from ACS.. or on ebay these people are ripping us off! these parts are cheap at the dealer and even more cheaper on line like at Iamgmparts.com All the hardware on the grill can be reused. those tabs have locking mechanisms built into the grill and bumper and some of the holes in the tabs take another easy locking mechanism.(you can see them in pics they are white and the tabs are black or yellow(depends on car color) the only extra parts that are needed are inserts for the splitter winglets, 6 screws for the wingles that come up glove box screw, and locking tabs for dive planes after you push through the slots.
09-26-2017, 08:46 AM | #17 | |
Dyno Show Queen LOL
Yes $405.00 in Houston at Coatings by Coats.. smaller rims cheaper. Id like to sell and buy 19s though! Cant decide Yellow or red caliper though!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 09-26-2017 at 08:59 AM. |
09-26-2017, 08:55 AM | #18 | |
Dyno Show Queen LOL
finger strength mine are aching ( The bezels were the toughest just wait til you put the new ones in they are very hard to press in) especially the lower corner to outside of the car had to use something to press against the bezel my fingers couldn't do it.. You have to work slow... keeping pressure on the part so once you unlock it by pushing up or down the tab your pointing at has a lip that has to clear on the fascia... keep pressure once it once its cleared or your go to the next one and it lock back in place with out you knowing! I started along the top outside edge and moved inward.. then did lower side 1st starting on opposite side.
09-26-2017, 09:34 AM | #19 | |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
09-26-2017, 10:04 AM | #20 |
Dyno Show Queen LOL
That one I dont know mine had 4 clips.. 2 on top start those 1st 2 on side must slide over to clear stop.. mine were not cemented on the clips should retain it.
all i had to do where push tabs over one direction to cleat the stops.
09-26-2017, 10:47 AM | #21 |
Yep. Someone had put JB Weld or something. I picked it off and it came off normally. Maybe they were working out kinks in the assembly when mine was produced in 10/2016.
***Pro-Tip*** I just shoved thin popsicle like sticks into every tab of the grill and it just pulled right off in about two yanks. I wish I had done this with every other piece. |
09-29-2017, 09:17 AM | #22 |
Dyno Show Queen LOL
Thanks to jason for sending the template. About ready to slot.. I ordered another set of dive planes last night skin.. I'm going to finish these up today and wrap the hood the same color as fuel lid.. semi gloss.. not quite as flat as the 1le's 3m flat 12 wrap.
Template seems to line up good probably won't go as wide as the template shows until I test fit back n fourth.
09-29-2017, 10:13 AM | #23 |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
cant wait to see the finished product EDFHobbies!
2014 ZL1 Camaro
1969 Camaro |
09-29-2017, 10:19 AM | #24 |
ZL1 1LE look with MagRide.. win win.
09-29-2017, 10:40 AM | #25 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
09-29-2017, 11:12 AM | #26 |
Bannable
I'd shave the tabs off of the canards and use 3m moulding tape in a heartbeat.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
09-29-2017, 01:32 PM | #27 |
Dyno Show Queen LOL
Try that and see how you like it.. I guess if you find some tape that tough as nails but thin as hair it possible. .
09-29-2017, 02:02 PM | #28 |
Drives: 16' Camaro E-Force SS Join Date: Jul 2016
sweeeeeeeeeeeeeeeeeeeeeeeet!
HOw does the zl1 compare to your wife's SC SS?
Leo
2016 e-Force 2SS Instagram @cleoent |
