11-10-2022, 10:07 AM | #1 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Factory Wickerbill
Those who went with LPO or from the parts department after delivery, could you please let me know if the Wickerbill is removable like the 14/15 Z28 was? Any pictures of it removed? I tossed it on my order but sometimes have second thoughts.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
11-10-2022, 11:05 AM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I believe it is. The 1LE that showed up at my dealership in August had the wicker and it had button head allen bolts. I have the install instructions at home. I did end up ordering the wicker two days ago.
11-10-2022, 01:59 PM | #3 | |
11-10-2022, 03:27 PM | #4 |
Lol, I should know in a few days
11-11-2022, 10:32 AM | #5 |
Here is the GM install instructions, it says if the car is to be "auto washed" i.e., run thru an automatic car wash, that the wicker should be removed.
ACCESSORY WICKER SPOILER PCKAGE INSTALL ID 84314077.pdf
11-11-2022, 11:34 AM | #6 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
Looks cool, but not sure it's very practical except on the track. It will likely reduce gas mileage, reduce acceleration and top speed, and it looks like need to be removed if you take the car through an automatic car wash.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
11-11-2022, 01:00 PM | #7 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
You can remove it, it’s not permanent. The holes are though
Sent from my iPhone using Tapatalk Pro
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
11-12-2022, 05:26 PM | #8 |
I didn’t order the car to sit in a parking with the hood up
11-12-2022, 05:29 PM | #9 | |
11-13-2022, 06:13 PM | #10 |
Hahaha, I wish it was so easy! My buddy was up in the air with either ordering an A10 SS 1LE with PDR and BCD or ZL1 M6 with BCD and PDR. He already has an '18 SS 1LE, he was looking for something different. When that ZL1 allocation came up, he jumped. It already went to 3000 status with a TPW of 12/12. I wish I could send you some of his luck!
11-13-2022, 08:43 PM | #11 | |
11-14-2022, 04:11 PM | #12 |
I'm pretty sure that is the case with most of us. Not sure what that has to do with the wickerbill though.
11-14-2022, 06:28 PM | #13 |
Drives: 17' 2SS Join Date: Sep 2016
It's perfectly fine to do whatever you want. I installed it on mine and it's a flimsy piece of plastic. the car gets tracked also, no need to worry..... its durable.
11-14-2022, 08:22 PM | #14 |
You provided a list of negative reasons for having it - unless, which you noted, one takes it to the track. I was simply responding that I didn’t order the car to take to car shows; I will be tracking, which is why I’m interested in it, but also being able to remove for different track events as necessary or any particular street driving. Basically, having the ability to cleanly remove and reinstall was my concern.
