09-22-2017, 04:50 PM | #141 |
Drives: 2017 2lt rs Join Date: May 2017
My 2014 gmc does this all the time.81deg here humidex makes it feel like 95
09-25-2017, 02:34 PM | #142 | |
Drives: '17 SS 50th Camaro Join Date: Apr 2012
Now if they could only fix the wind noise issue from the mirror that the car has been in 4 times before with
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410 |
09-25-2017, 03:45 PM | #143 |
Drives: Chevy Join Date: Jun 2017
I've found if you put the AC at 74 it doesn't fog. The fog is on outside not inside. Doesn't make it any less wrong on gm part. It's only in mornings on humid day.
09-25-2017, 08:01 PM | #144 |
Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
Every car is different... mine does it at temp settings above 74. All depends on how much air is leaking past the door on your particular car. Some folks lucked out and don't experience it at all.
09-26-2017, 09:41 AM | #145 |
Drives: 2023 2SS Convertible Join Date: May 2009
Its the Bat Signal!
09-26-2017, 11:13 AM | #146 |
Drives: 2016 Red Hot 2SS Join Date: May 2016
I experienced it pretty bad last night to the point I had to lean forward to see the traffic...very annoying. I'm ordering that large mouse pad and will trim it to fit.
10-14-2017, 10:11 AM | #147 |
So I got a call from the dealership and they are giving it a try but they told me they have to pull the doors and windshield which seems odd to me. Anybody else experience that? Anything I need to worry about with the doors being pulled?
10-14-2017, 01:24 PM | #148 |
Bannable
My local dealership wont address the problem because the TSB says fog "inside" the windshield and this occurs outside.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
10-14-2017, 04:47 PM | #149 |
Thank you Al Oppenheiser!
10-14-2017, 04:54 PM | #150 |
Drives: 2106 SS Join Date: Aug 2016
I had zero success when they did mine. Also make sure they replace the windshield with the correct one afterwards.
Sent from my SM-G935V using Tapatalk |
10-14-2017, 08:05 PM | #151 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
They don't need to pull the doors, they're ****ing idiots. The reason they pull the windshield is to access the vents. Tell them to read the TSB or find a new dealer
10-14-2017, 08:14 PM | #152 |
And I recommend not doing it. Just my opinion. This picture was right after.
10-15-2017, 11:47 AM | #153 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I made a cover for the vent for when the hot and humid weather returns. I may have to do over again as it is a bit rough looking but I have some time.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
