10-12-2016, 07:57 PM | #29 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
The full exhaust is stainless steel. I've done a full exhaust swap on my friends. Stainless steel can not rust...it will turn color, maybe that is what you are seeing, or dried mudd. It is not possible for aluminum or stainless steel to rust, and there is plenty of these materials under there. Some surface corrosion is normal. Any cast iron parts that aren't coated will have normal surface rust too...something is odd here.
10-12-2016, 07:57 PM | #30 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
This will work out for you. You watch.
Kindness and compassion #OthersFirst |
10-12-2016, 07:59 PM | #31 |
Drives: 2106 SS Join Date: Aug 2016
I am not a mechanic. But when the pipes leave the engine and come together and head to the back of the car the pipes are all red rust color. That was the worst. The others were some rust colors others almost a whitish color they were showing me
Sent from my SM-G935V using Tapatalk |
10-12-2016, 08:00 PM | #32 |
10-12-2016, 08:01 PM | #33 |
Man I wish I would have taken pictures
10-12-2016, 08:01 PM | #34 |
Blessed ❤️
What color was the mud. Did it happen to be orangy/red?
10-12-2016, 08:03 PM | #35 |
No. Zoom in on picture. Dark dark black. And like I said I got it washed many times. It rains here almost every day. There was nothing on the pipes
10-12-2016, 08:13 PM | #36 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
10-12-2016, 08:15 PM | #37 |
If it goes up on the rack I will take pictures
10-12-2016, 09:00 PM | #38 |
Drives: 2019 ZL1 1LE, MN6, SGM Join Date: Jun 2016
What dealer are you using?
10-12-2016, 09:01 PM | #39 |
Carl black Chevrolet
10-12-2016, 09:17 PM | #40 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Also, stainless steel's ability to mitigate rusting depends on the type of stainless steel being use. For instance, 409 SS absolutely will rust. 304 SS is much more corrosion resistant. |
10-12-2016, 09:20 PM | #41 | |
10-12-2016, 09:23 PM | #42 |
Drives: 2016 Camaro 2SS Join Date: Sep 2016
Rack? You mean lift? Cause rack means frame machine, at least here. Unless it's been wrecked, shouldn't be on the rack. Over 12k miles, in New England, had it on the lift multiple times, no rust at all.
