10-12-2016, 07:16 PM | #15 |
Drives: 2106 SS Join Date: Aug 2016
I washed it off right away and many many times through a car wash
Sent from my SM-G935V using Tapatalk |
10-12-2016, 07:44 PM | #16 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
3 months? I find it hard to believe with current technology that your car is rusting out. I live in the Pacific Northwest. If they rust that bad then my car will be toast in a couple months as well.
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
10-12-2016, 07:44 PM | #17 |
Is it rusted out or is there just surface rust?
10-12-2016, 07:45 PM | #18 |
I agree and I am very concerned. The service guy couldn't stop pointing out corrosion. All over!
10-12-2016, 07:45 PM | #19 |
They called it corrosion all over. Frame,tires,exhaust you name it
10-12-2016, 07:48 PM | #20 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Can you take a picture of your rusted tires?
Kindness and compassion #OthersFirst |
10-12-2016, 07:49 PM | #21 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
It's pretty odd, as I was just under my friends 11,000 '16 SS a week ago while we were installing new control arms, we live on the coast in Florida, I saw no rust...
It must have something to do with you running your car down into the mud...don't make a peep to your dealer about that. Pretty sure the rust/corrosion warranty is like 10/75 or more? |
10-12-2016, 07:49 PM | #22 |
I should have said wheel... it was on the inside looking out when it was on the rack
10-12-2016, 07:50 PM | #23 |
マスタング = 遅い
Corrosion on rubber tires and stainless steel exhaust...that would be a first.
10-12-2016, 07:51 PM | #24 |
They saw some mud up in the cracks and such. They wanted to call it an off road event. So I obviously needed to speak up so it wouldn't be classified as us going mudding in the car.
10-12-2016, 07:52 PM | #25 |
The rust on the exhaust is underneath. I promise you underneath they are not stainless steel. Thank you for questioning me though
10-12-2016, 07:53 PM | #26 |
Blessed ❤️
Keep us posted. Really wanting to know what happened here.
10-12-2016, 07:54 PM | #27 |
I will... makes my rear differential not so important right now
10-12-2016, 07:56 PM | #28 |
Warranty
GM vehicles are designed and built to resist corrosion. All body and sheet metal components are warranted against corrosion for 3 years or 36,000 miles, whichever comes first. Plus you’re protected even further from rust-through corrosion for a minimum of 6 years/100,000 miles (whichever comes first). Application of additional rust-inhibiting materials is not required under the corrosion coverage and none is recommended. See your GM dealer for terms of this limited warranty. Sent from my SM-G935V using Tapatalk |
