05-16-2016, 04:57 PM | #29 |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
Oy vey! Guess I'm headed to the dealership tomorrow....again.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
05-16-2016, 05:04 PM | #30 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
not all dealers do. found out from my dealer that they don't offer loaners anymore. if needed, they will hook you up with a rental company.
ask if the consecutive visits qualify you for some credit for some accessories. its worth a shot.
05-16-2016, 05:22 PM | #31 | |
#14294B: Product Safety - Ignition Key - (Aug 19, 2014) Subject: 14294B – Ignition Key Models: 2010-2014 Chevrolet Camaro Condition General Motors has decided that a defect which relates to motor vehicle safety exists in all 2010-2014 model year Chevrolet Camaro vehicles. There is a risk, under certain conditions, that some drivers may bump the ignition key with their knee and unintentionally move the key away from the “run” position. If this occurs, engine power, and power braking will be affected and power steering may be affected, increasing the risk of a crash. The timing of the key movement out of the “run” position, relative to the activation of the sensing algorithm of the crash event, may result in the airbags not deploying, increasing the potential for occupant injury in certain kinds of crashes. Until the recall has been performed, it is very important that drivers adjust their seat and steering column to allow clearance between their knee and the ignition key. Correction Dealers are to remove the key blade from the original flip key/RKE transmitter assemblies provided with the vehicle, and provide two new keys and two key rings per key.
05-16-2016, 05:24 PM | #32 | |
The BEAST
05-16-2016, 05:35 PM | #33 | |
https://gsi.ext.gm.com/image_en_us/g...91/4091587.gif https://gsi.ext.gm.com/image_en_us/g...91/4091586.gif part #23345002 pretty cool afterthought of them, easy to install to.
05-16-2016, 05:38 PM | #34 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
As a FYI, this isn't as wide spread as you may think. They highlight two Julian dates in the release. As 2015 wasn't a leap year the Julian dates align to the below production dates.
303 15 = October 30th 340 15 = December 6th Wonder if these Julian links apply to Production weeks instead of days?
05-16-2016, 05:45 PM | #35 | |
The BEAST
05-16-2016, 05:46 PM | #36 |
Lethal Camaro
I am tall person and have no idea how people were able to knocks those keys out. I refused the update 100 times. Now they ask my Dad every time he stops in as he now owns my old car.
05-16-2016, 05:47 PM | #37 |
Drives: 2016 RS Summit White Black Stripe Join Date: Apr 2016
[QUOTE=97one;9096256]Ok, V6 included then, not just V8's.
What date was your car built ? Thanks [/QUOTE The door sticker said December 15, 2015. Both rear toe links matched the recall and were replaced. The bushings were visually cracked when removed. |
05-16-2016, 06:03 PM | #38 |
Pretty sure the deal with it was the fact that the transmitter would break allowing the key to move freely. If you started the car with the key turned a certain way the transmitter would then point down due to the weight of the other keys on it making it easy to accidentally hit them with your knee, or hitting a bump would cause the car to turn back to the accessory mode. That's how I interpreted it. I've also seen a bunch of broken transmitters that people refuse to replace. Basically the same one on the Equinox, Malibu, and Cruze.
05-16-2016, 06:18 PM | #39 |
My car didn't show a recall online eithier I didn't know there was one on the toe links until my dealer told me at my first oil change
05-16-2016, 06:23 PM | #40 |
Maybe because it isn't a recall. It's a service update.
"there have been no failures in the field" Until that happens it will most likely stay as a service update and not a recall.
05-16-2016, 06:34 PM | #41 |
My paperwork from the work they did showed as a recall and they knew my car required it before they even looked at it. That's why dealer got my parts in before my appt.
05-16-2016, 06:34 PM | #42 | |
Drives: 2016 2ss Join Date: May 2016
General Motors ignition switch recalls - Wikipedia, the free encyclopedia https://en.m.wikipedia.org/wiki/Gene...switch_recalls |
