06-29-2022, 11:19 PM | #1 |
Drives: ZL1 Convertible; 6-speed Join Date: Sep 2021
Car’s not happy with No Lift Shift?
I’ve done it 2-3 times (100% WOT) and it honestly feels/sounds weird.
Is there a trick to it? Such as being in a specific mode or perhaps having to release the clutch real quickly or something like that? Tried launch control and it worked (although mostly spun lmao) and it sounded SAVAGE! Thanks in advance, |
06-29-2022, 11:32 PM | #2 |
Drives: 21 ZL1 Join Date: Feb 2022
Pretty sure you need to be in Comp mode. Double click TC button.
06-29-2022, 11:38 PM | #3 |
Also just saw a table that says 5,000 rpm minimum for this feature to be enabled?
Any other requirement apart from 100% WOT? |
06-29-2022, 11:39 PM | #4 |
PTM/Mode is a non-factor:
With regard to the effect of Mode selection on No-lift Shift, there is no difference between Tour/Sport/Track/Snow-Ice mode or PTM mode on the ability to perform the quick shifts. Most people either don’t keep the throttle to the floor, or don’t wait until they reach their Enable RPM before performing their shift. Both are required criteria to execute the No-lift shift feature. Lastly, the Enable and Target RPM is different for each engine application, and even within an application (as in the SS and SS 1LE).“ |
06-30-2022, 04:44 AM | #5 |
It is supposed to sound slightly weird as far as I can tell.
https://www.camaro6.com/forums/showthread.php?t=513327 https://youtu.be/4o22B6WIzhY?t=85
06-30-2022, 07:40 AM | #6 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
I have done it in sport mode. The default setting has it activating anywhere over at 5,200rpm.
You hear a little hiccup in the whine but the whine does not stop. The way I do it, I stab the clutch as fast as I can and make the shift then dump the clutch without letting off the gas. Works great. It took some practice for me to get it right. I will typically only use it from 3rd into 4th, and once in a while 4th into 5th. The downward shifts work best for me. 3rd into 4th and 5th into 6th. |
06-30-2022, 07:41 AM | #7 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
06-30-2022, 08:42 AM | #8 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Is there any particular reason you want to use NLS? Or is it just a general question? The car should be fine with the timing cut between gears and it shouldn't feel weird so long as you fulfill the requirements of the action.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
06-30-2022, 10:30 AM | #9 | |
Will report back. I’m sure I was not hitting that 5000 rpm req. |
06-30-2022, 10:59 AM | #10 |
2-3 is always a tough one. I would suggest giving it a few practice pulls normally before you try to do it using NLS; you might even want to do it for the easiest transition (3-4) to get a feel for it prior to trying to do 2-3. I personally don't use it because I think NLS is just too slow in stock form. It can be adjusted through tuning but, I still think it's not worth using--not that you asked or anything, I'm just offering feedback. Good luck with your experiments.
2018 Audi TT ▊RS
06-30-2022, 04:15 PM | #11 |
Drives: 2023 Corvette C8 Join Date: May 2022
The A10 has no lift shift…just sayin….
2023 Corvette C8 70th Anniversary Edition
———Gone But Not Forgotten——— 2022 Camaro ZL1 Convertible (Never Delivered and won’t forget) 2019 Camaro SS Convertible 2019 Corvette Grand Sport Convertible 2013 Corvette Grand Sport 2013 Challenger SRT 392 1995 Camaro Z28 |
06-30-2022, 05:47 PM | #12 |
That’s really neat for the girls in the group. LOL
Just kidding. To each his/her own.
06-30-2022, 11:34 PM | #13 |
06-30-2022, 11:37 PM | #14 |
So I tried it out today.
WORKS! Just like some said, the SC whine briefly paused but car keeps accelerating. Unfortunately tried 2-3 and moneyshifted to 1st, saw 7,500 revs, tires buckled. It was quick though, and car is running just fine. Kinda intense break-in for 600 miles LOL Will keep it 1-2 and 3-4 for now. You’d have to be brave for 4-5 NLS. |
