Old 06-14-2022, 05:12 PM   #1
KryptoniteSS
Drives: Camaro SS
Brakes & Rotor Kit Recommendation
Have a 2016ss and looking to upgrade brakes and rotors. Daily driver for work, any recommendations are appreciated. Was currently looking at the Z26 or 27 Powerstop kit.
KryptoniteSS is offline   Reply With Quote
Old 06-14-2022, 05:18 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
oem rotors and z26 pads
kropscamaro16 is online now   Reply With Quote
Old 06-14-2022, 05:22 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
Z26 has been no issue for me on the street or at the drag strip. I bought everything as a kit under one part number. The last time I looked for the kit there was no stock. So here are individual part numbers if you have the same outcome.
Double check these numbers on Powerstops site if you choose that direction to confirm the numbers haven’t changed.
Amazon.com: Power Stop Z26-1474A Z26 Extreme Performance Carbon-Ceramic Front Brake Pad Set: Automotive
https://www.amazon.com/Power-Stop-Z2...rch&pldnSite=1
Amazon.com: Power Stop Z26-1718 Z26 Extreme Performance Carbon-Ceramic Rear Brake Pad Set: Automotive
Front rotors - AR82182XPR
https://www.amazon.com/Power-AR82182.../dp/B01ELZVKZ8
Rear rotors - AR82184XPR
https://www.amazon.com/Power-AR82184.../dp/B0741Z3WPQ
Old 07-17-2022, 09:00 PM   #4
gmw0181
gmw0181's Avatar
https://www.shopchevyparts.com/perfo...-92290217.html
gmw0181 is offline   Reply With Quote
