06-10-2022, 08:10 AM | #29 | |
Drives: Chevrolet Camaro Join Date: Apr 2022
06-10-2022, 09:44 AM | #30 | |
I understand this is completely invalid in a scientific sense, but if you insist on this level of accuracy, we won't be able to converse about much—my car is an A8, there is no way I can produce apples to apples test data against an M6 car, and in very few cases do we have perfectly comparable cars under the exact same conditions anyway.
06-10-2022, 10:43 AM | #31 |
Edit ; I was wrong about some of those tires. I believe all run-flats should hook when warm on dry pavement, road course, or the strip.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 06-10-2022 at 11:08 AM. |
06-10-2022, 10:48 AM | #32 |
I can't vouch for all of those, but most of them are definitely not run flats. It's almost a contradiction in terms for DR and runflat.
06-10-2022, 10:57 AM | #33 |
I removed those tires because I guessed. Pretty sure all manuf. makes racetrack run flats.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 06-10-2022 at 11:11 AM. |
