05-19-2022, 11:31 AM | #1 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
DIY alignment
After installing SPL rear toe rods, fixing installation of one of the rubber insulators on my Vorshlag camber plates and installing new street tires I decided to try to correct the alignment as much as possible for the trip to the alignment shop. As it turned out, I was a lot closer than I thought.
05-19-2022, 01:59 PM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Im very interested in being able to do this.
05-19-2022, 06:53 PM | #3 |
05-19-2022, 07:16 PM | #4 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Here's my DIY alignment thread:https://www.camaro5.com/forums/showthread.php?t=566970
05-20-2022, 07:19 AM | #5 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I've been using this calculator for a few years now to get all the toe sorted:
https://robrobinette.com/DIYAlignmentCalculator.htm It's been pretty spot-on when checked on a hunter aligner afterwards and all it requires are 2 parallel strings (I have lately switched to using laser diodes that project a line in place of strings and still get the same results). Have a camber/caster gauge for the rest, but specifically on this car only camber since caster isn't adjustable. Decent one of those can be found for under $200 and pays for itself if you're going to be doing alignments yourself more than once or twice.
2017 SS 1LE.
05-20-2022, 11:22 AM | #6 |
05-20-2022, 05:39 PM | #7 |
Great info. I used toe plates because I had them but found the string lines to be so accurate that there was no adjustment needed when I got close enough using strings to look at the plates. And of course the plates aren’t going to help with thrust angle. I hadn’t seen the calculator before.
