10-04-2017, 02:43 PM | #1 |
Drives: 17 SS a8 Join Date: Feb 2010
Will they fit? 325/50/15
I will let you know in a few days.
These are going on a friends 2016 Camaro and if they fit I will promptly be ordering me a set. I will post up more pics when we actually get to try them on the car.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
10-05-2017, 04:01 AM | #2 |
Think you're going to need the Carlyle rear brake kit to get 15s on the back of a 6th gen SS.
10-05-2017, 04:38 AM | #3 |
It is on the way along with some forgrstar rims.
10-09-2017, 08:40 PM | #4 |
Drives: 16 summit ss Join Date: Oct 2016
They fit. Would like them to be tucked a little more but not bad.
10-09-2017, 08:46 PM | #5 |
Can't wait to try at the track Friday !
10-09-2017, 09:01 PM | #6 |
The skinnys really blend in. You can barely tell they are there. Here is one more angle.
10-10-2017, 07:45 AM | #7 |
Drives: Me: '16 2SS yellow, Wife: '16 1SS Join Date: Feb 2016
looks pretty cool!
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque |
10-14-2017, 11:26 AM | #8 |
Drives: 2019 Chevy Camaro ZL1 A10 Join Date: Sep 2017
Awesome! Thank you for the info, I appreciate the Pics!
10-18-2017, 04:28 PM | #9 |
I couple of notes about the install. this car already had the bmr parts. everything fit but the rear bar needed a shallower head bolt and one of the spacers had to be ground a little shorter.
the brake lines rub the rim if the car is on the lift. we ground the sharp edges(casting marks) off the top and bottom of the spindle where it was closest to the rim. 1st trip to the track at 5psi of boost on e40 netted a 6.99@101 with a 1.60 60' the car would have gone quicker with more aggressive brake boosting but the track started bitching about no roll bar. it was pretty cool at the track and the tires needed a decent burn out to hook. the car was losing traction on some of the first runs. when he came back to the pits the tires were still cool to the touch. after doing a more aggressive burn out they hooked well. cant wait to see it turned up and I cant wait to get a set of my own. I am going to try bronze.
11-01-2018, 09:46 AM | #10 |
Horsepower whisperer
Drives: Camaro Join Date: Jun 2017
What rim offset/ width did you use to clear?
11-01-2018, 10:56 AM | #11 |
11-01-2018, 11:01 AM | #12 |
Drives: ZL1 1LE Join Date: Oct 2018
Did you all go with the 15s because of tire growth? I was considering the 325/30/19s (ET Street SS not the Rs). If I go 19s would I tear up the car during a burnout or at launch?
2nd crazy question: when going from 19 to 18 at what point do you need a speedometer adjustment? ET Street SS also come in a 345/35/18...would the 18s allow enough room for growth and how off would my speedo be? |
11-01-2018, 01:33 PM | #13 |
I went 15’s because they work better for drag racing. More side wall allows a longer contact patch. Also tires are cheaper.
Speedo chages are a result of tire height and have nothing to do with rim size. No idea if those other tires mentioned would fit.
11-12-2018, 10:59 AM | #14 |
Thanks for the info man, what adjustment in camber did you have to make to accommodate fitment if any at all
