Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 06-25-2016, 08:28 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Hazards and dome light come on by themselves
As the title states, my hazards and interior dome light come on when I go through the traps all by themselves. They will not shut of until I pull back into the pits and shut the car off and cycle the key a couple times. I'm sure it pisses off whoever I'm running and it's pretty annoying.
I've tried pulling the abs fuse and relay, that didn't work. I know the hazards are controlled off the bcm. Any way that I can cut the wire to them? I'm not running wheel speed sensors, wondering if that's doing it?
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 06-25-2016, 03:06 PM   #2
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
CHRISTINE!!!!
BFASTNOTLAST is offline   Reply With Quote
Old 06-28-2016, 01:46 PM   #3
ttshovel
ttshovel's Avatar
No one has ran into this issue before?
Old 06-28-2016, 01:49 PM   #4
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 07-03-2016, 09:11 AM   #5
clarks hennessey
Drives: 2010 hennessey camaro ss
I got the same problem . It sucks.
clarks hennessey is offline   Reply With Quote
Old 07-03-2016, 10:05 AM   #6
ttshovel
ttshovel's Avatar
Are you 4l80 swapped? Curious if we share that aspect?
Old 07-05-2016, 07:24 PM   #7
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I had a very similar issue when the voltage regulator on my alternator crapped out... It reset when it cooled a bit and then happened again... It was putting out the proper voltage but any hard pull would drop the regulator out and some of the same things would happen again....
I ended up pulling the alternator and sending it in for a look see... Thy replaced the voltage regulator and called it good to go...
My hazards came on, the dome light, the stereo etc... Voltage dropped to 12 volts, (battery) and all kinds of things lit up...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 07-05-2016, 10:04 PM   #8
ttshovel
ttshovel's Avatar
Hmm the alternator is only a couple months old but who knows, anythings possible. It didn't do it my first time out with the car it's only been the past 2 outings with it. I will try and keep my eye on the voltage next time out. Thanks
Old 07-07-2016, 12:27 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Mine was a little older but it had way less time. About five passes at the mile. It's electronic. Who knows.
Old 07-25-2016, 06:03 AM   #10
flyby
Drives: 2010 Silver SS
I've had the same problem twice. Usually happens after hard launch only. Runs are recorded on computer, voltage drop not at issue. Most likely a product of the body control module, at least that's what we figure. Yes I am 4l80e swapped more than 2 years ago.
flyby is offline   Reply With Quote
Old 07-30-2016, 09:05 AM   #11
ttshovel
ttshovel's Avatar
interesting, it can't be coincidence that were both 4l80 swapped. I went to the track again last night and it didn't do it....
Old 04-07-2017, 12:36 AM   #12
BradySS
Drives: 2010 Camaro 2SS
I just had this problem happen to me tonight. Just got the car back from changing the gears and made a pull. Hazards came on. Turned car off, cycled the key and started the car the lights turned off. Made another pull, lights on again.
The only things I've changed since this has happened have been the gears and trutrack (shouldn't have anything to do with it) and I put some Corbeau FX1 pro seats which got rid of the airbags and sensors.
Setup on the car is TH400 5300 8" stall, cam and bolt ons.
Any help would be greatly appreciated.
BradySS is offline   Reply With Quote
Old 04-07-2017, 06:46 PM   #13
xXSicSicSicXx
Drives: 14 1LE
sounds like a short to ground
xXSicSicSicXx is offline   Reply With Quote
Old 04-07-2017, 11:27 PM   #14
BradySS
Ill check my grounds tomorrow. I tried letting the car sit for 10hrs with the negative cable undone just to see if that might help but it didnt.
