12-23-2019, 11:35 PM | #1 |
Drives: 2016 Chevrolet black Join Date: Oct 2017
Transmission flush/change cost
My dealer is charging me 450$, which seems a bit expensive, in Dallas Texas. (Automatic)
12-23-2019, 11:41 PM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I've seen as high as $600 for the new fluid and flush procedure.
12-24-2019, 12:27 PM | #3 |
Drives: 2020 Camaro RS Join Date: Oct 2019
The flush & fill, as required by TSB #18-NA-355, requires between 20 and 22 qts of transmission fluid at approximately $15 a qt (blue label Mobil1). That's about $300 in trans fluid alone. Add 2-4 hours of labor (depending on who you ask) and it adds up quick.
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
12-25-2019, 03:26 AM | #4 |
are you still under the drivetrain warranty? 5 year 60,000 miles they should be doing it for free.
12-26-2019, 10:08 AM | #5 | |
I have read some only paying $350.00 for the fluid flush out of pocket.
2016 NFG 1SS A8
12-27-2019, 12:36 AM | #6 |
my dealer only has it in qts. $12.95 is the price they gave me but i have and wholesale account.
01-01-2020, 04:30 PM | #7 | |
According to NADA, 49.6% of dealership gross profit comes from Service & Parts. New vehicle sales is approximately 26% of gross profits. Used car sales and F&I make up the rest. The $15 a qt I quoted in my earlier post was really just a guess. The point I was trying to make is there's a relatively high materials cost associated with the procedure. Therefore, the amount the OP was being charged is not unrealistic, albeit maybe not the best price available somewhere. No expertise implied or expressed.
RWT
01-06-2020, 05:17 PM | #8 |
Weird I called 3 dealerships today and received 3 different quotes, 425$ from the dealership I purchased from, 190$ from reliable chevrolet, and 260$ from friendly Chevrolet.
01-06-2020, 05:20 PM | #9 |
01-07-2020, 09:12 AM | #10 |
Drives: 2017 Convertible 1SS A8 Join Date: Aug 2018
Most dealers will charge you for the fluid flush but only drop the transmission pan and put in the 7.4 quart service fill instead of replacing all of the fluid. Therefore, I would just pay for the pan drop service and save yourself $200. If you have the ability to jack the car up safely, you can do this yourself for around $80. You'll need a fluid pump to refill the transmission since there isn't a fill tube; I used a hand pump garden sprayer to refill mine.
Kooks 1 7/8" LT catted headers, Katech Ported TB, SoCal ported IM, Green filter, Tuned by BCP, Borla S-Type axle-back, BMR springs, BMR front sway bar endlinks.
01-07-2020, 04:28 PM | #11 |
Drives: camaro rs v6 2017 Join Date: Oct 2019
Just tell them you have the shudder and get it done for free..go over a few posts on what the shudder sounds and feels like so you can explain your "situation"to them..according to the tsb there is no need for them to replicate the problem. You may not have it now but it will come.
