Old 09-23-2016, 01:36 PM   #15
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Active rev match is for downshifting...throttle blipping.
No lift shift means at WOT you keep the throttle pinned, no lifting when you shift. The car senses the clutch engagement and kills a little timing to keep the revs in check.
Yes I understand this.
I was just wondering if the no lift shift employed the same throttle management.
Thor142 is offline   Reply With Quote
Old 09-23-2016, 01:41 PM   #16
Iron Oak
Club Motorsports Track Op
Iron Oak's Avatar
Drives: STI, Land Rover and future 1LE
Rev Match should just be a simple algorithm based on the vehicle speed and what gear you are selecting, then it adjusts the engine RPMs accordingly.
Each gear will have a specified speed range and the associated revs for that gear at that speed etc.
Does that make sense?
Iron Oak is offline   Reply With Quote
Old 09-23-2016, 02:00 PM   #17
Thor142
Thor142's Avatar
Sort of. I haven't used it on the 6th gens, yet. I wouldn't doubt if it's evolved to that level...
On the 5th gen ZL1, it just held the throttle plate closed enough to avoid hitting redline while you engaged the clutch to shift. You were able to hold the accelerator to the floor and bang through the gears
Ahhh...thank you.
Didn't we bet a beer on something? LOL I can't remember what it was now.
You going to the Glen for HPDE on Oct 1?
Old 09-23-2016, 02:03 PM   #18
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Don't know yet, but the PTM software is new, so I am thinking it would be more advanced than say in a 5th gen ZL1...
Old 09-23-2016, 02:07 PM   #19
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
ok. who wants to be the guinea pig and try it on there current 16 SS?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 09-23-2016, 02:31 PM   #20
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
When I had my tuner set up No lift shift on my car he said it was already set up in there from the factory. I'm pretty sure you can do it on a stock 1ss, but you have to rev it out to 6200+.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 09-23-2016, 02:35 PM   #21
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Ahhh...thank you.
No...:(
But next year. Yes. And I'll be sporting a new ride.
Old 09-23-2016, 02:50 PM   #22
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Really? I have read multiple times that the regular SS's don't have it and I thought you needed PTM to have function? I'm sure if the regular SS had it, it would be in the owners manual and someone would have posted about it by now?
Old 09-23-2016, 03:35 PM   #23
Ian SS
Ian SS's Avatar
He said multiple times that it was already there he just tweaked it a bit. It already had parameters for throttle position and rpm limit. He said on the 5th gens he has to set it up manually but my car was already set up for it.
SLO 1SS - sold
1SS MRC NPP 6MT
Old 09-23-2016, 03:39 PM   #24
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
The regular SS has the no-lift shift, but I think you have to have Rev Match turned on to do it.
Old 09-23-2016, 03:42 PM   #25
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Humm, I had no idea...I wonder how may guys racing these things are lifting at full throttle lol?
So rev match on, and WOT and no lift shift works? Does it need to be in a certain driver mode?
Old 09-23-2016, 04:00 PM   #26
Ian SS
Ian SS's Avatar
Just drove a 2017 1ss 6 speed and confirmed it has No lift shifting standard. I was in sport mode with rev match on but I dont think the rev match has to be on.
SLO 1SS - sold
1SS MRC NPP 6MT
Old 09-23-2016, 04:01 PM   #27
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Does this only work at WOT, or at a certain throttle position and further?
Old 09-23-2016, 09:03 PM   #28
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
I assume the 6th gen is similar, but on the 5th gen ZL1, timing and boost (for the ZL1) is not cut during the shift. NLS is available in all driving modes not just in PTM. If you shift right before redline, the rpm will just drop and not hit the rev limiter. If you shift too early the rpm will just flare up.
DrkPhx is offline   Reply With Quote
