Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 06-15-2016, 09:00 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro V6 LT LS ACS-T7 Splitter 48-4-007
2016 Camaro 6th Generation ACS V6 LT LS ACS-T7 Splitter
•The latest Gen6 Camaro is simply stunning, won't take long to realize that a new front splitter will set it to a new level. Not only will it add an extra visual dimension to the car’s sleek build, but it will add aerodynamics and guile at high speed to a vehicle that already handles like a dream.
Available in a black primer finish, Carbon Flash Metallic Black and body colors, please make correct selection when ordering..
The Gen6 Camaro Splitter carries the following features as standard:
•Improved frontal airflow management
•Manufactured in an OEM-validated RTM composite material
•Use of OEM mounting points for simple installation.
For those that love to adorn the car themselves. You will be pleased to know that installation is less than 15 minutes; the ACS-T7 Splitter is installed using the OEM mounting bolts . Fits all 2016 Camaro I4 & V6 front fascias.
Winglets have over the last few decades been used by both commercial and corporate jets. Jet designers have long known that airflow off the end of a wing caused drag. With the implementation of the winglet airflow was improved and planes moved more efficiently. Same principal applies to the latest Camaro Winglets / Deflectors line.
Application Guide
◦Camaro I4, V6 2016-17 Coupe, Convertible.
Item # 48-4-007
Website Link : http://www.rpidesigns.com/shop/item....s-t7-splitter/
RPIDon is offline   Reply With Quote
Old 05-28-2020, 07:08 AM   #2
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2016-2018 Camaro 6th Generation ACS V6 LT LS ACS-T7 Splitter
RPI Designs is offline   Reply With Quote
Old 05-28-2020, 09:55 AM   #3
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Order #245153
I ordered a set of color-matched side skirts and a splitter on January 31st.
It's March 28th and still nothing. No response to emails or phone calls.
This company is a complete scam.
Read their reviews:
https://www.facebook.com/rpidesigns/community
H4r0ld is offline   Reply With Quote
Old 12-07-2020, 08:19 AM   #4
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 08-01-2021, 08:00 AM   #5
RPI Designs
Old 08-01-2021, 09:04 AM   #6
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Care to address/resolve this sale?? https://www.camaro6.com/forums/showthread.php?t=595327
driven2exceSS is offline   Reply With Quote
Old 01-06-2023, 11:07 PM   #7
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...s-t7-splitter/
