Old 06-15-2020, 05:01 PM   #1
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Sound tube repurposing
I never got around to removing the sound tube on my car and finally found that it is useful after all.
While installing a curb alert on my camaro I needed to run the sensor wire into the cabin, through the firewall.
So, I thought I'd just run the sensor wire through the sound tube, and while I was at it and had plenty of room in my newly repurposed wiring conduit, I ran the power wire out through the conduit and over to the fuse block. The power wires needed to be extended some but it is all pretty clean.
As a note, about 2" toward the firewall from fitting between the lower tube and the upper tube there was a plug of what looks like foam packing material. I just reached in with needle nose pliers and snatched it out. I also put it back in before connecting the two pieces. Maybe to prevent smells from entering the cabin??
I drilled a hole in the bottom of the tube where it connects to the round device, no clue what it's called, to enter with my wires. I then put RTV around the hole to seal it.
I ran the wires in front of the main radiator with some of GMs wires.
I would suggest putting some kind of covering on the wires to protect them, such as the braided type I used.
It all came out pretty stealth. I've included some pictures.
Sorry for the blurry 2nd picture, but I think you get the drift.
overdriv is offline   Reply With Quote
Old 06-15-2020, 06:38 PM   #2
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
How do you like the Curb Alert, and is the alert speaker loud enough to hear if the stereo is on?
2004YZFR1 is offline   Reply With Quote
Old 06-16-2020, 10:31 AM   #3
overdriv
overdriv's Avatar
I really haven't driven the car since installation. My car is not a daily driver so it will be awhile before I can report on it.
The alarm in the cabin is fairly loud, I guess it would depend on how loud you listen to music??
Old 06-19-2020, 10:25 PM   #4
2004YZFR1
Thanks overdrive.
Old 07-18-2020, 01:11 PM   #5
overdriv
overdriv's Avatar
As an update, been using the curb alert to locate the car when parking.
Works very well. I go in slow and when I hear the beeps, stop. Always 12" +/- an inch or two from curb.
