07-31-2019, 05:46 PM | #1 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
Scissor Lift
Has anyone used one for their 6th Gen Camaro? I want to get one for doing oil changes, pull all four tires for general cleaning and when I need to polish the lower sides instead of laying on my side in the carport, so any helpful advise would be appreciated.
07-31-2019, 05:59 PM | #2 |
376 cubic inches of fun
For oil changes, use Race Ramps. Safe for you and your car!
07-31-2019, 07:06 PM | #3 |
I have looked at the full race ramp setup, a little more pricey than a lift unless I can find one that doesn't run around 2k.
07-31-2019, 07:17 PM | #4 |
Drives: '17 2SS Vert H50, A8, F55, NPP Join Date: Jan 2018
I have a mid rise scissor lift
https://www.ebay.com/itm/6600-lb-Aut...edirect=mobile And use 4 aluminum body seam pucks https://www.ebay.com/itm/High-Qualit...edirect=mobile Works like a charm. |
07-31-2019, 08:22 PM | #5 |
Drives: 2017 2SS Manual Join Date: Apr 2017
Take a look at Quickjack as well
07-31-2019, 08:50 PM | #6 |
Drives: '17 ZL1 Join Date: Jul 2016
I had a scissor lift. It was always in the way and not that practical for most jobs. I sold it and now have 4 identical aluminum floor jacks. That setup works very well. I wouldn't trade it for a QuickJack.
07-31-2019, 09:03 PM | #7 |
I was looking at the Restyler Magna Ramps, a little cheaper than the pit stop race ramps but really the same.
08-01-2019, 08:39 AM | #8 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I use the quickjack 7000ext. work out great. just a PITA to set up and make perfect for pinch points.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
08-01-2019, 09:10 AM | #9 | |
Drives: 2016 Camaro 1SS, Jet Black, M6 Join Date: Sep 2018
If you use them with the QuickJack put the ones in the front in the lift point furthest to the rear. Otherwise the QuickJack will not reach it, even the 7000EXT.
2016 Camaro 1SS | M6 | Jet Black | Roto-Fab Dry w/SND Tube Delete | AWE Touring Cat-Back Exhaust |
08-01-2019, 10:06 AM | #10 | |
HYPER SS
Ordered: 1/15/2016
08-01-2019, 10:17 AM | #11 | |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Same here takes me less than 10 min from starting to the car in the air. Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
08-01-2019, 11:21 AM | #12 |
Drives: 2019 Camaro LT1 Join Date: Jul 2019
I just got a Atlas td6mr portable scissor lift, haven't used it yet, I need help getting it out of my truck
Saying THANKS don’t cost a dime so hand it out freely!
08-01-2019, 06:19 PM | #13 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I just got the 7000SLX Quick Jack from Costco for $1,000.00.
Strange as it was advertised as 5000SLX, and was sold out within the first day of the ad. In fact it went on BO, and 2 days ago it was delivered, and I just noticed it was the 7000SLX. Still recovering from hip surgery, but once I'm good, the QJ will be installed QUICKLY! Anticipation is killing me every time I see the 3 boxes! This will make detailing the wheels so much easier, as well as fluid & bushing changes and flushing the brake fluid system...time to lube the creeper wheels!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
08-01-2019, 09:05 PM | #14 | |
Did you get the extensions? If you didn’t and don’t have the EXT model you won’t be able to lift your Camaro Sent from my iPad using Tapatalk Pro
Ryan
