Old 07-06-2018, 11:10 AM   #15
mcintyre1969
mcintyre1969's Avatar
Drives: 1968 SS/RS, 2006 H2 2016 2SS White
Originally Posted by Glen e View Post
I will say this again. They will either find that the battery is not a problem or they will replace it. And then a year or two down the road it might happen again. Many of us have had this happen. There's something in the Camaro system that drains the battery through no fault of your own. I don't believe GM is giving us a good answer on this. I've gone through two batteries in my Camaro and they can find no fault found. I now have a quick disconnect switch on the battery so I can disconnect it if it's going to sit longer than two or three days…I'm actually going to get rid of the car pretty soon because of this problem.
Curious what you would get next?
2016 2SS White fully loaded
mcintyre1969 is offline   Reply With Quote
Old 07-06-2018, 12:34 PM   #16
DangerZL1
Drives: 2023 Black ZL1 Auto
Not trying to thread jack, but what car is next for you? Another Camaro, or back to a Vette?
Old 07-06-2018, 12:41 PM   #17
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I'm going to disappoint everybody and just drive my SUV. I just need something that's easy to get in and out of, and I'm pretty much done with performance vehicles. Would love to have an Aston Martin, but I think my HR-V will do fine. I've owned it for a couple months now. The Camaro is going to go to another family member. So I won't really be selling it…My nephew is aware of the goofy batt problem.
Naturally I had to put wheels , paint the brakes and a lower stripe on it.....
Old 07-06-2018, 03:34 PM   #18
DangerZL1
An Aston would be an awsome car. They have some of the best lines of any car including Ferrari's. I'm sure the Honda is a detailer's showpiece of your handiwork. If you leave the site after your lucky nephew gets it, we're going to miss your input.
Old 07-06-2018, 04:50 PM   #19
flaps100
flaps100's Avatar
Drives: 2017 Camaro 2.0 RS
Well they towed my baby away, could not get it to jump start. They showed up in under 20 minutes from the time I called GM. Great tow driver, very careful, really good at what he does. So far amazing service, now lets hope the dealer can get me going asap. Flaps
flaps100 is offline   Reply With Quote
Old 07-06-2018, 05:54 PM   #20
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Why do batteries fail after only 3900 miles?
Well, it could be a bad battery, but also, how do you drive only 3900 miles in 13 months? Man, if I lived in the land of no winter, I would drive my Camaro more like 39,000 miles in 13 months.
Old 07-06-2018, 06:09 PM   #21
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
The batteries are not failing. There is something in the system the drains the battery. The batteries are AGM batteries and are high-quality.
And many of us drive 4000 miles in 13 months, I have about six different things that I can drive and/or ride, so my car doesn't get used all the time. Only for fun when I want to.
Old 07-06-2018, 06:24 PM   #22
flaps100
flaps100's Avatar
Here ya go
We drive it on fun trips mostly, have another car to take daily to work, on the lousy roads to work, but the Camaro does get driven every other day at least or so, to and from shopping, dinner, and some road trips , short but planned and fun.
Old 07-06-2018, 06:24 PM   #23
Rnovrit
Rnovrit's Avatar
Drives: 2018 NFG ZL1-1LE
Are you guys just letting the car sit or do you have it hooked up to a battery tender? I would assume a battery tender would solve this issue and extend the life of the battery. Well not solve the GM issue but at least keep the car charged.
Rnovrit is offline   Reply With Quote
Old 07-06-2018, 06:45 PM   #24
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Of course many of us are using a tender, and you're right it solves the problem. However there are many others that are in some type of garage or condo facility that don't have power going to the car. Those of the ones that get dead. The problem is you shouldn't have to use a tender, and Chevrolet admits that. Every car has to passthe test of at least a car sitting at the parking garage at the airport and make it 4 weeks… That's a given....if it doesn't pass that test you got a problem and Chevy lawsuits.
Old 07-06-2018, 07:07 PM   #25
Rnovrit
Rnovrit's Avatar
Thumbs up
Very true. I was wondering more if the vehicles still had a shorter than average battery life while using a tender. Guess I worded it a bit wrong. Thanks for the input.
Old 07-06-2018, 09:11 PM   #26
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Not denying the possibility or likelihood of parasitic loss although it does seem to be hit or miss where as some owners never experience the issue and others run into this nightmare.
Another thing I wanted to bring up though is the assumption that the battery is only 13 months old... or basically only as old as when you got the car .. and this .. isn't true. The battery has been sitting under the hood uncharged for the most part ever since the car was constructed and sitting months at the lot with only a few short test drives...its very possible even for a new battery to die on the lot before you even buy it, and once it does even if they jump it, its life span is severely weakened.
Need4Camaro is offline   Reply With Quote
Old 07-06-2018, 10:28 PM   #27
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Perfect answer. Sitting on the lot, they go dead and are permanently damaged.
Dead battery = done battery. Oh you might revive it, but it's performance and lifespan are greatly reduced, then they fail.
Car still needs to be thoroughly checked. Load test, starter amp draw test, parasitic loss, and all those wonderful grounds that GM does so haphazardly.
Some even have front to back batt cables fail.
Why is Discharging a Car Battery Too Far So Bad?
Even though 80 percent of the capacity remains when a car battery dips to around 10.5 volts, the battery is considered to be fully discharged because taking the cycle any deeper will cause irreversible damage the plates through excessive sulfation.
While normal sulfation is reversible, excessively draining a battery, or leaving it in a state of discharge, will allow the soft lead sulfate to crystallize. At that point, charging the battery will still cause some of the sulfation to reverse, but any crystallized lead sulfate will remain on the plates. This sulfate cannot, under normal circumstances, return to a solution in the electrolyte, which permanently reduces the available output of the battery.
The other detrimental effect of allowing crystallized lead sulfate to form is that it effectively shortens the lifespan of the battery in an empirically measurable way. If too much of this crystallization is allowed to occur, the battery will no longer be able to provide enough amperage to start the engine, and it will have to be replaced.
https://www.lifewire.com/car-batteri...-to-die-534765
7
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 07-06-2018, 10:39 PM   #28
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
do you just leave the trunk open or do you close it?
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
