11-19-2017, 04:29 PM | #29 | ||
I used to be Dragoneye...
11-19-2017, 06:38 PM | #30 | |
Drives: 2SS 1LE Join Date: Oct 2011
(yep, OEM sensors, got 4 of em, you can find them online for decent prices) Sorry to be a pain |
11-19-2017, 06:48 PM | #31 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
If you rotate tires and the sensors change locations you have to reprogram/reset. So new OEM sensors would have "new to the car identity" and would need to do the same, I would guess. If you put the currently programmed sensors back in the same location, I would guess no resetting would be necessary. But for $35, a programmer is an easy solution. My inexpert two cents.
11-19-2017, 10:00 PM | #32 | ||
Get the programmer. You'll need to reset the TPMS system when you rotate or replace wheels. |
11-20-2017, 12:19 AM | #33 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I've had GY Supercar tires on my C6 Corvette and now on the Camaro along with The Michelin PSS. As long as the tires are inside and not outside in direct air they should be fine. I mean unless you live up in the far North regions of Canada where it gets to be single digits for weeks to months on end. |
11-20-2017, 07:53 AM | #34 |
Townhouse, no garage, outside.
11-20-2017, 08:42 AM | #35 |
Drives: '18 1SS 1LE Join Date: Sep 2017
11-20-2017, 09:00 AM | #36 |
11-20-2017, 01:01 PM | #37 | |
My dealer actually kept my 1LE in a storage garage before I bought it at the end of January. It was the first one they received. We had such a warm winter last year that I, by luck, didn't drive the car when the temps were low. I had R888s on my last car and they made it through the winter without cracking but they weren't as soft as the GYs. |
11-20-2017, 02:26 PM | #38 |
08-13-2023, 07:50 PM | #39 |
Drives: 2024 2SS vert w/M6 & Dual Mode. Red Join Date: May 2023
Is there any current ,updated info from Camaro6 drivers regarding driving with these tires ? I have no thoughts of driving the car at all during 4 of the coldest months here in the N.E. but driving these summer tires is not advised by Goodyear in temps below 70 degrees .
I would think prudent use above 50 degrees should be ok. No ? |
08-13-2023, 09:03 PM | #40 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
08-17-2023, 11:17 AM | #41 |
Drives: 2018 Chevrolet Camaro 1SS 1LE Join Date: Oct 2020
This is the official bulletin regarding this matter:
https://static.nhtsa.gov/odi/tsbs/20...32138-0001.pdf |
