10-16-2017, 03:17 PM | #1 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
JDP Camaro 9.90 @ 145.16
We've been chipping away at our set up and we got it into the 9's this past weekend. We need to get our 60ft down but we should see mid to low 9's next season with some additional changes. We run at 4500 FT here in Utah also.
This car is full weight at 4400LBS with driver. We're running a 429ci LSx with an F-1X ProCharger, JDP Centri Camshaft Package w/6-Bolt Heads, Squash Fuel System w/ID-1000 Injectors, Alky Control Meth System, KOOKS 1-7/8" LT's (Going 2") and 3" KOOKS Quad Tip cat-back, 4L85 Trans w/YANK 4000 Converter, Ridetech Triples w/JDP 15" Conversion and more. Kind regards, Jordan Priestley 801-545-4215 |
10-16-2017, 04:53 PM | #2 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Good god Almighty! Congrats!
10-16-2017, 05:08 PM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Nice. This is where i want to be with mine. What rear gear?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
10-16-2017, 05:13 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Yeah theres 2 tenths easily just in the 60ft.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
10-16-2017, 08:46 PM | #5 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
That's bad a$$ fo sho!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-16-2017, 10:21 PM | #6 |
Drives: camaro Join Date: Oct 2013
Nice! What has been done to the diff/axles to keep it alive?
10-17-2017, 06:41 AM | #7 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Way to go JDP!!!
10-17-2017, 07:11 AM | #8 |
Drives: Camaro Join Date: Mar 2013
I just ran, in the 1/8, last weekend: 1.41, 4.12, 6.44 at 106.5.
Any guesses what it would do in the 1/4? |
10-17-2017, 07:44 AM | #9 | |
Thank you!
We've got the ZL1 M6 rear differential with a 3.73 gear. We should see 2-4 tenths pretty easy once we get into the 1.3-1.4 range. We typically see .1 in the 60 translating into .2 on the big end. Appreciated! We've got a ZL1 rear end conversion with a 3.8" DSS carbon driveshaft. Quote:
10-17-2017, 07:46 AM | #10 |
Yeah, I figured. You were pulling on me pretty good by the end of the 1/8.
I would be happy with low 10s. |
10-17-2017, 08:59 AM | #11 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
similar to my setup. 427/f1x
so far my best is 9.2@155mph and that was leaving from idle with 0 boost. So there is def a ton left in your setup. congrats on hitting the 9s.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
10-17-2017, 09:05 AM | #12 |
Instagram: Sangstah
sweet, congrats on the time!!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
10-18-2017, 08:06 AM | #13 |
8.60 @ 157 @ 4200lbs
Congrats. What boost you running.
10-18-2017, 08:22 AM | #14 | |
We appreciate it! We're running 18psi currently and it made 1032 WHP and 830 WTQ through the 4L85 trans. Kind regards, Jordan Priestley 801-545-4215 |
Tags |
5th gen, camaro, drag race, jdp built, jdp motorsports |
Thread Tools | |
