11-16-2023, 11:54 PM | #1 |
Drives: Chevrolet Camaro Z28 (2015) Join Date: Feb 2023
which ctek for z28 battery
hello fellow Z28-ers ... I want to buy I CTEK to keep the battery healthy during the cold Washington state winter... any recommendation on which model to use for the Z/28 battery?
2015 Red Z/28. Seattle area |
11-17-2023, 05:23 AM | #2 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
You have a smaller battery than typical Camaro, but the CTEK won't care if it's an SS, ZL1, V6 or Z/28.
I use a CTEK Multi US 7002 on the ZL1 and am very happy with it. I use a Battery Tender Jr. on the 2010 SS when it's sleeping (If you ever go with a Battery Tender, use the Jr. version only to maintain, the regular Battery Tender models suck). Both keeps the batteries fresh and topped off, ready to go and have for several years. Both will maintain AGM or lead-acid without issue.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-17-2023, 05:40 AM | #3 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
I lol'd a little, I use a NOCO GENIUS5, 5A Smart Car Battery Charger for both of my AGM's
11-17-2023, 08:28 AM | #4 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
All that you need
https://www.amazon.com/Battery-Tende...s%2C120&sr=8-5 Pop the hood, put black on bare metal bolt... there's a post on the driver's side fender by airbox. Then red connects to charging port by master cylinder. Done
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
11-17-2023, 08:58 AM | #5 | |
11-17-2023, 10:19 AM | #6 |
thanks folks!
11-17-2023, 11:42 AM | #7 |
11-17-2023, 12:20 PM | #8 |
Drives: 69 Z/28, 70 Z28, 99SS, 15 Z/28 2018 Join Date: Sep 2016
I use Battery Tenders on all my cars. Never a problem!
Buddy
69 Z/28 burnished brown, m-21 owned since 1978 70Z/28 forest green M40 CE block PROJECT 99 SS hugger orange 6spd no t-tops 1 of 54 15 Z/28 white AC, radio |
11-17-2023, 02:37 PM | #9 |
Drives: 2014 Z/28 #48 CTF|White, 2012 e63 Join Date: Nov 2022
Thanks for the info, I just bought the tender off Amazon. Been on my list of things to do for the winter.
11-17-2023, 03:10 PM | #10 |
I bought this https://www.dougshelbyengineering.co...wiring-harness for my Z, so much better than the charging cord hanging off the fenders or rear bumper.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
11-17-2023, 05:21 PM | #11 |
Life's just a Ride
I bought this for my NOCO's so it can stay permanently under the hood and Poof you can Jump start if needed and my Trickle fits on the other side, no more gator clamps lol.
https://a.co/d/fSsyli3 |
11-17-2023, 06:01 PM | #12 | |
11-17-2023, 07:05 PM | #13 |
Life's just a Ride
Yeah, I'm not installing them in the Trunk but in the Engine bay where the Jump ports are. I just added another Ground on the Block to the chassis
11-18-2023, 04:34 AM | #14 |
See my posts in this thread about the CTEK MUS 4.3 TEST&CHARGE with Recondition setting compared to Delran’s Tenders …no comparison Cteks are by FAR superior.
https://www.camaro5.com/forums/showt...highlight=Ctek I’ve had both and would NEVER AGAIN trust hooking my car up to a Delran tender with those simpleton red & green lights On multiple occasions with both a JR and Tender+ they turned off (red light never turned green it just went out …WTF !) and this was on a good battery. I contacted Delran and was told the charger reached it max time limit which isn’t written up anywhere and that I must have a bad battery…WRONG!!! IMO before hooking your battery up to a Delran tender you have to ask yourself the Dirty Harry question “Are you feeling lucky today?” I suspect that with the larger CCA in our cars combined with the parasitic drawn built into our cars the Delran tenders can only charge so much given they more for motorcycle and smaller CCA car batteries. ps - I use the Recondition setting once a year on my AGM battery Last edited by camguynj; 11-18-2023 at 08:48 AM. |
