05-20-2018, 10:13 PM | #15 |
Drives: 16 2SS Convertible, 08 JKU Join Date: Jan 2016
That sounds interesting. I too keep the partition up all the time. Having an effective trunk light would be nice.
'16 2SS Convertible - Blue Velvet, 6M, MRC, NPP, 56R, Nav, Ash Gray, & Silver Rally.
'08 Rubicon JKU - Jeep Green, 6 spd, 5" Terraflex, LoD Off-road armor, Warne 9.5, 4.88 gears, 37x12.5R17 |
05-22-2018, 12:14 AM | #16 | |
Drives: 2016 2SS Convertible Join Date: Oct 2017
First picture is the stock lighting with the divider in place. Second picture is the lighting I have now. Third picture is one of the bolt LEDs (one on each side of the trunk).
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
05-22-2018, 03:39 PM | #17 | |
Drives: 2017 Grey RS Convertible Join Date: Apr 2018
05-23-2018, 01:52 PM | #18 |
I can certainly understand that concern. But this is such a minor modification it was difficult for even me to screw it up!
06-10-2018, 08:06 PM | #19 |
Drives: 2017 2SS Covertible Join Date: Jun 2018
I'm planning to build a different trunk divider in order to also use the part of the trunk below the top down.
I don't have any picture yet because I'm still waiting the parts. My idea is to use a cargo net and hook it horizontally just below the 8" of height, 36 x 22. In this way I can store items below it without the fear the turbulence will lift them up while the top down is operating (it's crazy paranoid but there is the risk, better safe than sorry) Then another cargo net that hooks on the two existing top locks used by the divider but instead of going all the way down the bottom of the trunk, it stops at the same height of the previous net. They can be seamed together using a small stick. Using the OEM locks from the divider, the sensor will still work but I will have more room to work with. The issue of using the net is that if you load heavy stuff and they move on hard brakes or accelerations, the net may not be strong enough to contain the items out of the operating area but it depends on these 'sticks' I mentioned as reinforcement. I can replace the net with two thin boards but for storing it when you need the whole trunk, it could be annoying. when the parts will come I will let you know more. |
06-10-2018, 11:01 PM | #20 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I have simply unbuttoned the bottom of the divider and let the top two stay connected. That allows me to store my spare tire in the trunk with no problems.
I think it would be ideal if the divider was permanently connected on top and simply rolled up to be out of the way.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
06-11-2018, 08:12 PM | #21 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
06-11-2018, 10:22 PM | #22 |
Yep. No problem.
I bought the modern spare with it's case, etc. There is an inch or two between the lowered top and the spare. The only issue is that you can't clip the bottom of the trunk divider. I will try to take some pictures tomorrow to show how much space. I tried before but it was too dark, the pictures weren't good enough.
06-28-2018, 03:33 AM | #23 |
I just completed the idea I mentioned above
I made a brand new divider, with clips, magnet sensor, where I can use the space below the folded top and no modification in the car required. I really wanted to make it 100% reversible. just in case the whole DIY guide is here: https://www.camaro6.com/forums/showt...0#post10233040 and here are few pictures of the final result: |
06-28-2018, 11:49 PM | #24 |
Drives: 2017 Camaro 1LT Convertible Auto V6 Join Date: Jul 2017
Looks great! and a very good idea thank you for sharing.
07-05-2018, 12:24 PM | #25 |
Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
Only works if dealer lets you keep old part, which I doubt.
2016 2SS Convertible, A8, Dual mode exhaust, MRC, Nav, Stainless pedal kit, all-weather mat upgrade, SS center caps, Hurst billet shift handle, Camaro logo armrest
06-17-2021, 10:59 AM | #26 |
Drives: 2017 2SS Convertible Join Date: Mar 2021
Simple and elegant solution
Hi All,
I have a much simpler and more elegant solution to divider delete - small neodymium magnet for 30 cents or so and double sided tape. Have a look - attached photo. No need to cut the divider like d00mz did or upgrade it like The Alien did (this is the safest option I have to agree, however his contraption is fixed and limits you from using the trunk space with top up - myself I look to get as much storing space as I can due to small trunk size). Of course you need to be careful not to get the top down when storing items above those 8 inches in the back of the trunk - not to damage the top or items in the trunk! If you plan to follow my approach be aware that magnet's polarization does matter - if taped on the wrong side it won't work (believe me I have tested it ). BR, Jarek
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) Last edited by Jarek; 07-05-2021 at 02:09 AM. |
07-18-2021, 09:46 PM | #27 |
Drives: 2017 Camaro 2SS Vert Join Date: Apr 2019
Well if anyone doesn’t want there divider I’ll gladly take it. Mine broke so wouldn’t mind a replacement
07-19-2021, 03:34 AM | #28 |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
Trunk divider delete
I posted a thread on this a while ago too. Also used a neodymium magnet but mounted it on a piece of plastic with a floor mat clip and wrapped in carpet tape. Easier to take on and off than sticking the magnet alone and looks slightly nicer
