05-02-2019, 08:45 AM | #1 |
Drives: 23 2SS 1LE Join Date: Feb 2019
Paint for engine bay
Hey guys. So I wanted to try some DIY engine bay dress up. I have a lot of paint and plastidip, which I have seen work fine on many pieces in the engine bay on other cars. I just have the V6 and I don't track it so it never gets too crazy hot.
My question is, will regular paint/plastidip still work under the hood or do I need to go buy high heat engine paint? I only have that in black right now but wanted to do some black/red splatter paint to make it unique. I wanted to do this on the engine cover, fuse box cover, and air box cover. I was thinking plastidip so it can be removed if I change my mind later on. Any thoughts?
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
05-02-2019, 09:28 AM | #2 |
Interested in this as well. I am going another route (hydro dip) but it requires a base paint first then clear coat. My thoughts would it should be fine on the plastics as those are not getting too hot.
05-02-2019, 09:35 AM | #3 |
I was considering hydro dipping as well but I enjoy the DIY part and the only place around me I know can get pretty expensive, pretty fast. I will do the airbox and fuse box in plastidip first and see how that goes. I still have a few interior pieces to get started on this weekend as well.
05-14-2019, 11:30 AM | #4 |
Drives: 16 Summit 2SS, 92 Arctic Formula Join Date: Dec 2017
Regular spray paint will be fine on plastics.
I have my valve cover covers painted with 10 coats of normal satin white spray paint. It says on the can "binds to plastic" and 2x coverage. Then i used a red paint pen and repainted the letters on the "CAMARO" of each side. Seems to be holding up nicely with no flake or cracking. Hope this helps!
2016 2SS / Summit White / Adrenaline Red / MRC / NPP / CF5 / 5LQ 6 Piston front brakes with slotted & vented 2 piece rotors / A8 / Satnav / Low Gloss Black 5 spoke
