Old 03-05-2019, 11:47 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
anyone install the delrin BMR cradle bushings yet?
how you like them notice anything?
Old 03-06-2019, 02:24 AM   #2
JCunningham
Drives: 2017 2SS M6
found the GM solids scored for $378.50 with newyear discount https://www.shopchevyparts.com/perfo...-92298179.html
Old 03-06-2019, 10:54 AM   #3
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Not sure if it happened to you yet, but these are officially back ordered nation wide - did you get the last one??
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 03-06-2019, 01:02 PM   #4
JCunningham
Drives: 2017 2SS M6
no they just sent me a email 60 days
Old 03-06-2019, 04:04 PM   #5
Silver2ssA8
Drives: 2017 Silver SS
I have the BMR cradle lockout, installed myself which is why I went this way. Definitely worth it in my opinion, rear end doesn’t “shimmy” over bumps while cornering hard anymore. Transitions in tight turns seem a little quicker, as well as staying straighter when launching with wheel spin.
Silver2ssA8 is offline   Reply With Quote
Old 03-07-2019, 01:23 AM   #6
JCunningham
Drives: 2017 2SS M6
now the parts completely disappeared from there sight
Old 03-07-2019, 01:40 AM   #7
JCunningham
Drives: 2017 2SS M6
do you have any info on the back order?
Old 03-07-2019, 08:15 AM   #8
Shawnqa800720
Drives: 2018 1SS
I called the parts dealer that I ordered from as well as a few other major parts warehouses, and it is a nationwide stock out. He said these things go one of several ways, the two most likely are:
1. They get notice from GM that the parts will be ready near the 60 days
2. The part gets discontinued and all orders are cancelled
This is a bummer. I want to wait the 60 days to see where this goes as I definitely want the true solid rear cradle bushings. But, I'd hate to wait the 60 days and find out that the part is discontinued and I need to go BMR anyway. I have a track event in mid April that I'd love to have these installed for, but am going to be patient. My next track event isn't until early June, so I should know by then and be able to change direction if needed.
Old 03-07-2019, 10:31 AM   #9
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Maybe GM realized that this one upgrade pretty much gets you all the handling benefits of the ZL1 1LE and it is hurting ZL1 1LE sales???
Just a wild guess, because truly, that is the ONLY weak point in the SS 1LE and ZL1's suspension. Most of the increased feel and increased stability in the ZL1 1LE is coming from those solid rear cradles. 95% of the front suspension is the same across all 3 models.
That would suck if they actually do discontinue them, but probably unlikely. When I got mine last year, they were on back order as well. I waiting about 4 weeks I think and picked them up from Wildhammer Motorsports.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 03-12-2019, 07:50 AM   #10
boostedlt1
Drives: 2016 Camaro SS
I wonder if any other companies will be coming out with solid cradle bushings in the near future. I feel like the 5th gens have alot more options.
2016 2SS M6
Procharged, LTs, BTR cam, Vengence pistons, LT4 HPFP, DSX aux kit, DSX flex fuel kit.
boostedlt1 is offline   Reply With Quote
Old 03-21-2019, 06:26 PM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
great mod...I just did this simple mod and feel it was worthy. Why swap the bushings and increase noise, vibration, harshness when the lockout fills the slop in the factory units? Everything fit great which usually isn't the case with aftermarket suspension parts.
Old 03-21-2019, 10:42 PM   #12
JCunningham
Drives: 2017 2SS M6
from what i hear is the GM aluminum ones dont add any noise, vibration, or harshness. The Delrins i put in my 5th gen didnt either.
Old 03-21-2019, 10:45 PM   #13
TRZ06
TRZ06's Avatar
My ZL1 1LE solid rear cradles added nothing negative as far as NVH. That is myth. What it does do over the lockout kit is takes longer to install, but the trade off is 100% rear play gone, not just 80%-90%
No wrong answer here, but I can tell you 100% certainty that there is no added NVH.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 03-21-2019, 10:48 PM   #14
JCunningham
Drives: 2017 2SS M6
i ordered the GM aluminum ones because it comes with new GM bolts even to do a alignment. Got it for $378 but did not no until the next day they were back ordered. they say 60 days.
