Old 01-30-2019, 05:22 PM   #29
desertmonkey
Drives: '17 SS 1LE
Originally Posted by pbsinternet1le View Post
That's an alignment issue not a tire problem more than likely. Did you have it aligned after you bought it ? Many have reported poor factory alignments.
Nope. I'm guessing it is too late to salvage my tires with a track alignment at this point?
Also, if it was poor alignment from the factory, is it even possible to get Chevy to absorb the costs of new tires?
desertmonkey is offline   Reply With Quote
Old 01-30-2019, 08:41 PM   #30
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Maybe? They should offer to correct alignment for first 5000 miles. My dealer did. I have 6 track days 11500 miles on a set before 2nd set. G3s wear prettt well for what you get on track. I tried the stndard track alignment but understeer is still there. I ended up maxxing front at -2.4 f and using -1.5 rear zero toe and combined street track wear was very even.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 01-30-2019, 09:07 PM   #31
desertmonkey
Drives: '17 SS 1LE
Interesting. Time to have a chat with my friendly dealer. They basically "blamed" the uneven wear on my track day and said only fix is to replace tires
Old 01-30-2019, 10:04 PM   #32
pbsinternet1le
Track day with standard street alignment would understeer and cause outside tire wear or rollover. The outside of the G3 looks different than the rest of the tire though even new. People look at them and think its bald on the outside but it is part of the design. You will see the deep wear indicators if you look closely.
2017 1LE Hyper Blue
Old 01-31-2019, 04:02 AM   #33
wnta1ss
Drives: 2017 Camaro 1SS
These types of tires do look bald to some guys. Friend of mine knows a guy with a Z06/Z07 and the moron at the inspection station refused to put a sticker on it, told him he needed new tires. He HAD new tires, it was a new car and the tires (Sport Cup 2?) are DOT. Tech was just too dumb to understand.
Old 02-01-2019, 09:22 AM   #34
1LEASYE
Drives: 2018 Camaro 1SS 1LE
Another item as well, when I had my Transmission/differential/brakes flush and my oil changed, the service writer had on my ticket the mechanic said the Boxes and Springs would not pass inspection since my inspection is due in March.
What are these ""Boxes" that the mechanic is speaking of was speaking of?
2018 Camaro 1SS 1LE
1LEASYE is offline   Reply With Quote
Old 02-01-2019, 12:45 PM   #35
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Central Virginia's version of "muffler bearings"?
'18 1SS 1LE Black, PDR
Old 02-01-2019, 01:09 PM   #36
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
btw if any of you are intersted my buddy wrote a book to help check it out!
https://www.amazon.com/Better-Car-Co...n+driving+book
Old 05-06-2019, 07:03 PM   #37
metros11
Drives: 2018 SS 1LE
Found this thread through a search, lots of helpful hints. Had an additional question though. What do you guys do to protect the paint, if anything? I've raced Lemons, Champcar and AER with a beater and never worried about paint for obvious reasons. But a bit concerned about taking a fairly new car with atrocious factory paint to an event where it might get blasted with debris. Suggestions? Or am I overthinking it.
metros11 is offline   Reply With Quote
Old 05-06-2019, 07:36 PM   #38
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
xpel trac wrap or road warrior plus to name two of many.
Old 05-07-2019, 08:35 AM   #39
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
I have my front fascia covered in Xpel PPF. I dont want that getting damaged as it is more expensive than the tracwrap. Has anyone put tracwrap over the Xpel PPF? OR is there some other way I can protect my car that wont ruin the current PPF
artey34 is offline   Reply With Quote
Old 05-07-2019, 11:55 AM   #40
Boost Creep
Drives: '18 1SS 1LE
3M painters tape.
Double up on the most prone areas.
Old 05-07-2019, 03:16 PM   #41
artey34
artey34's Avatar
Originally Posted by Boost Creep View Post
3M painters tape.
Mainly just in front of the rear wheels and the front splitter?
Old 05-08-2019, 03:10 PM   #42
Apex_Missing_Ape
Drives: 2018 2SS 1LE
Something else I bring to the track the me is a set of wheels chocks. Since you won't want to use the e-brake after a session, wheel chocks added extra peace of mind over just putting it in gear when off.
As far a track alignment, there's a massive difference between factory and track alignment when it comes to understeering and even tire wear. Get the alignment for sure.
Apex_Missing_Ape is offline   Reply With Quote
